Not bad I assume you are using a Zanflare or Liitokalla tester as they are around 7% higher than rated.powerX said:Capacity test showed these numbers:
2386
2341
2366
2397
2360
2364
How is that?
Wolf said:Not bad I assume you are using a Zanflare or Liitokalla tester as they are around 7% higher than rated.
That being said I have found some of these chinese cells quite good in quality.
Also the tester will discharge to 2.8 V rather than 3V which most of these cells are rated at so it gives you an extra 100 mA or so.
All in all if you had a bunch of these cells good for you!
