BMS Common vs Separate port
Hello,
Could someone tell from own experience which of the BMS is better? With common or separate ports?
Some people say that common is much better, but i found information where separate is also have advantages.
got confused :|
t.y.
Common port is for systems where you have the load and charger coming from same source.
Split source /load is generally made for where you want the BMS only to cut the charger and not the load. Like Ebikes.
Sed6 likes this post
But on the powerwall it’s more important do not cut the load. while ebike is charging not while the driving so whats the problem to cut the load (motor) if the bike is charging plugged in to the socket?
How do you intend to start using an ebike IF load output is cut after charging? Once again IF you have separate Charge and load use separated ports. Unless your Charger talks to the bms
OK. looks like i still have a gap of knowledge about the way BMS works Smile
So in other words i understood that for offgrid (or ongrid) powerwall i have to buy BMS with common ports.
IF you skip ebike bms then thats what you Will get.
