Barkers Random Projects
- Mar 26, 2020
- 9
Hi everyone,
I'm looking to build a li-ion battery for my travel trailer.It seems like a lot of off gird invertersare setup to have a charging voltage under the 58.8v that is required to fully charge a 14s lithium pack.
I've looked at seemingly countlessinverters and this is what I've found that may work for my situation
[size=small][size=small]I'm leaning to the SRNE because it fits my needs, and the price is good- although I'm not too sure of the brand.[/size][/size]
[size=small][size=small]I'm planning on having a 14s BMS on the pack, but I do want the option to fully charge the pack but won't store it in that configuration. The BMS will manage the cutoff voltage for me.[/size][/size]
[size=small][size=small]Anyway, am I thinking about this to hard? Or are the other suggestions for a 2500-3000w off gird inverter? Specifically ones with an automatic transfer switch. At the foreseeable future I don't plan on hooking solar up to them, but it would be a nice option in case I change my mind. Also I'm hoping to stay at or around$600as well, but the more I look into it it seems unlikely.[/size][/size]
[size=small][size=small]Should I reconsider a 7s pack instead? It seems like this would expand the inverters available, but I'd have to use larger ga wire to compensate for the lower voltage.Or should I build a 13s pack instead of a 14s? The low voltage cutoffwould be triggered sooner on these inverters- seems like a lot of them cutoff of 40v, which would leave the cells at about 3.08 on a 13s pack - it will preserve the batteries a bit more but I'd like to use more of the capacity of the cells that a 14s pack would provide.[/size][/size]
[size=small][size=small]I've also considered just buying a standalone inverter, transfer switch, and charger - but I can't seem to find a standalone charger that will provide enough voltage with a decent amount of amps.[/size][/size]
[size=small][size=small]Anyway, thanks in advance![/size][/size]
- AIMS picoglf20w48v120vr - this will charge at a max of 57.6v at 5a - i'd like to have more charging current, but 57.6 is too low for me
- MPP[size=small]3048LV-MK - I can't find the voltage range for this or a price. Does anyone know if the charging voltage is configurable for this?[/size]
- Singeneer APC3048NC - 58.4v at a 'Boot' voltage - close but still isn't the full amount
- SRNE 2500W SR-HF4825U60 - charging voltage appears to be configurable to 60v and current of 30a
