Novice DIY Wizard seeks diagram review
You dont need a laptop to check out batrium as eample and not the others either.
In Batriums case i run WatchmonUDPListener that i built for them. That reads the data and inserts it into InfluxDB or sends to Mqtt. I then show this on a webpage and i know other people done dashboards in NodeRed as example. Making the Windows software not needed to monitor. Its enough you have it for configuration.
I guess you can do the same with the other systems that have interfaces.
