Mike's DIY Powerwall
I have been working on this project for a few months now, so rather than try to rehash everything thus far, I will just start the thread by discussing where I am at now, then post updates along the way.
I am building packs of 120 cells in parallel. I would estimate the average capacity per cell to be 2200mah. That gives me ~264ah per pack. This is the very first pack i made. I went with similar design as Peter, with a few changes. I am doing 6 wide (3 bus bars) rather than 4 (2 bus bars). Additionally, I decided to fuse both ends only because the fuse wire is so cheap, why not. Aside from that, it's mostly the same.
[Image: dUxLKJiQ.jpg]
Each bank consists of 7 packs, or 25.9v nominal voltage. This is the first bank I built. At the time of this post, it has been in service for 6 weeks and is still working great. The voltages per pack (when charged) only differ by 0.02v at most. When discharged, there are 2 week packs that fall to around 2.8v while the others remain at 3.3v. I will need to rebuild these packs at a later date.
[Image: jBowwAov.jpg] [Image: FuWlLVYA.jpg]
This is the second bank (packs 8-14) that I just finished a couple of days ago. I'm trying to come up with a way to capacity test the packs so I can group similar capacity packs together.
[Image: hJxfucCa.jpg]
oooo
Nothing too special here. A standard Tracer charge controller and cheap inverter. I'm working on upgrading the equipment slowly. I did receive a PCM60X earlier this week which has been running for a few days now. I will post pictures/updates once I have more to share.
[Image: Bji3sKl8.jpg]
oooo
What is the small box, on the bottom?
Cell progress: 2016/10/17:                                       Business Owner                                       Projects:
180cells@2.0                                             http://18650shrinkandcellholders.com                     www.PortableRecycledPower.com
600cells@2.1-2.6a        8Kw Powerwall
70cells@2.7a+        1Kw PowerBlade
        16Kw PowerRack (concept)
        12v LED Sconce
Toochi84 Wrote:What is the small box, on the bottom?
It's just a digital display for the charge controller. It shows the voltage, amps, etc. It has since been replaced with the PCM60X. I'll post a new picture once it is all pretty and organized.
<!-- m --><a class="postlink" href="https://www.amazon.com/Sun-YOBA-Tracer1210RN-Tracer1215RN-Tracer2210RN/dp/B00ECVWDGC/">https://www.amazon.com/Sun-YOBA-Tracer1 ... 00ECVWDGC/</a><!-- m -->
oooo
mike Wrote:Nothing too special here. A standard Tracer charge controller and cheap inverter. I'm working on upgrading the equipment slowly. I did receive a PCM60X earlier this week which has been running for a few days now. I will post pictures/updates once I have more to share.
[Image: 3WllrcH.jpg]
Are you charging the batteries direct from the tracer? Are you disabling the float charge?
Yes. They are connected directly. I just picked a battery setting that had a maximum voltage (bulk, float, equalization) below 28.7 (4.1*7). It is not the correct way to do it but it worked for the couple of weeks until my PCM60X arrived Smile
oooo
[Image: UQue8ktR.jpg]
New 320w panels ready to install as soon as I can figure out how to attach them to the roof! Also converting the battery system to 48v for this. I need to go back and resolder 7 of my 14 packs so the busbars alternate each end.
oooo
They are alot bigger than i thought they would be. Even tho i saw the dimensions when purchased. Reading and handling are two very different things.
        12v LED Sconce
mike Wrote:[Image: ORNsS2U.jpg]
wow, that's a lot of solar power you got there Big Grin NICE!
Please do share how you end up mounting 'em
(Thanks for your awesome youtube channel!)
super heavy too when you try to move them solo. I have 3 and it was awkward trying to maneuver them on to the rack. I'm not sure about roof mounting, but i used super strut attached to a wood frame to mount mine. Might be able to devise some roof mounts for the super strut.
Off Grid Setup
3 - 320watt 24v Panels - MPPSolar 2424LV-MSX - 672 Cell 96p7s 5.5kw Power Wall
Retired pack 2kw 420 Cell
On Grid Setup
44 - 250 Watt Panels with Enphase micro inverters
100 User(s) read this thread:
hbpowerwall (07-07-2017, 07:28 AM), AZ_Tekkie (06-23-2017, 05:03 AM), Chickey (06-22-2017, 05:13 PM), Brian Lawrence (04-16-2017, 08:37 PM), daromer (06-23-2017, 05:40 PM), Minatugar (05-08-2018, 02:04 AM), Sean (02-14-2017, 03:16 PM), mike (08-07-2018, 11:13 PM), Toochi84 (09-27-2017, 03:38 AM), goodnowm (10-16-2017, 05:15 AM), Swolrath (06-02-2017, 12:13 PM), AveRageJoe (07-07-2017, 04:29 AM), BigBen (06-20-2017, 03:35 AM), station240 (02-14-2017, 09:44 AM), PaulKennett (06-02-2017, 11:36 AM), Joaquinsfy (02-15-2017, 09:23 PM), 49er (07-03-2017, 04:36 PM), NiVa (06-20-2017, 12:34 AM), Lux_Gamer (06-24-2017, 10:06 AM), Andreas Kvernes (03-21-2017, 09:48 PM), owitte (06-20-2017, 08:52 AM), opus40 (06-01-2017, 12:45 PM), RudyLiPower (06-24-2017, 04:09 PM), miwall (04-09-2017, 08:06 PM), lgeo (05-29-2017, 04:49 PM), dakoal (02-27-2017, 10:58 AM), VdVoort4 (05-16-2018, 06:53 PM), Grazor (05-24-2017, 01:00 PM), Majorphill (06-20-2017, 12:20 AM), Elwood (02-18-2017, 10:16 PM), frasernator (02-10-2017, 03:21 AM), riveracc1 (08-10-2017, 08:28 AM), coolfx (06-25-2017, 06:35 AM), Herebus (04-10-2017, 08:57 AM), timholmesjr (05-08-2017, 01:42 AM), Rerouter (02-13-2017, 07:49 PM), cstanley (06-01-2017, 02:33 PM), BatteryDIY (02-10-2017, 06:16 PM), DanielD (04-09-2017, 03:37 PM), ruby2 (06-23-2017, 02:27 AM), JustJim (12-26-2017, 02:40 AM), Korishan (06-23-2017, 06:29 PM), P.Tasyo Powerwall (04-09-2017, 04:50 PM), PAF (06-23-2017, 09:51 PM), brettwatty (02-21-2018, 01:18 AM), FERCSA (06-25-2017, 11:24 AM), rumey (02-15-2017, 01:45 PM), Prahe86 (08-30-2017, 06:41 PM), Janis (03-07-2017, 07:45 PM), FireFrog (02-14-2017, 02:18 AM), APD (02-15-2017, 02:38 AM), pfromero (03-10-2017, 06:39 PM), Alexander (02-06-2017, 09:11 AM), theDIYHobbyist (02-15-2017, 02:30 AM), Yves (02-11-2017, 07:16 PM), Bob Muster (03-07-2017, 01:25 AM), Jose Reyes (05-14-2017, 09:19 PM), Franky Beuselinck (06-12-2017, 07:34 PM), Gazza (02-14-2017, 12:32 AM), Daniel Barbu (02-17-2017, 09:32 PM), steve (02-17-2017, 12:42 PM), Batrium (06-23-2017, 12:40 PM), Darmok (06-01-2017, 04:56 PM), Wattsup (03-01-2017, 12:18 AM), Scepterr (06-23-2017, 05:37 PM), Project (04-09-2017, 02:57 AM), Batteriapan (03-13-2017, 02:12 AM), BobinTN (04-17-2017, 07:20 PM), Tristan Timmer (04-02-2017, 11:12 AM), Felineman (03-11-2017, 01:18 AM), Swazytrain (03-19-2017, 09:26 PM), Tshillingburg (10-29-2017, 01:46 AM), Frnandu Martiński (07-05-2018, 02:52 PM), egam (06-23-2017, 05:35 PM), skyfridge (03-11-2017, 12:30 AM), CrankyCoder (07-11-2017, 04:03 PM), Alec_J (08-17-2017, 03:36 AM), flight4900 (06-21-2017, 08:51 AM), Droid126 (05-24-2017, 06:30 PM), Sohax (04-11-2017, 01:31 PM), C11MAN (04-10-2017, 05:16 PM), jdeadman (06-23-2017, 05:26 PM), charlie246 (05-25-2017, 04:03 AM), Rechargedwalls (04-09-2017, 02:02 AM), crud (10-09-2017, 08:42 AM), 2146 (06-01-2017, 09:28 PM), wim (06-08-2018, 07:35 AM), hugo5464 (04-09-2017, 09:52 PM), wimpie007 (06-25-2017, 03:46 AM), coconut2k13 (04-11-2017, 01:29 PM), MajStealth (06-01-2017, 08:46 PM), ericg (04-20-2017, 07:50 PM), Joe Farrugia (11-16-2017, 12:32 PM), frnandu (08-29-2017, 09:09 PM), DoubleZed (04-21-2017, 07:17 PM), melsom (06-20-2017, 09:35 AM), Brian Drury (06-25-2017, 06:55 AM), typ49 (06-23-2017, 08:40 AM), VicRC (05-12-2017, 08:39 AM), Tommy Ng (06-08-2017, 11:38 PM)
