How to build a pack with mixed cells?
Hi all,
this is my first forum post, probably not the last.
I have some 48V-plans for the future, but I will write something about that in a separate thread.
By a lucky coincident I got a bunch of cells today (really unplanned) with a total of 923.4Wh.
A large portion of that are 30x 21700er cells with around 18Wh each.
But unfortunately the 21700er are from 4 different suppliers,
mostly 3.6V 5Ah but also some with 4Ah and 4.9Ah.
Can I put all the 21700er together into one pack?
Surely I will do some cell analysis to test the remaining capacity.
As I am aiming for a 48V configuration, a 14S or 13S configuration would be the way to go here.
Thanks for helping out a beginner.
Best,
nurF
MissSolar likes this post
(04-21-2020, 03:35 PM)nurF Wrote: Can I put all the 21700er together into one pack?
I'm assuming these are Lithium-ion (3.0v to 4.2v) so I'd recommend 14s (14 in series) for a 48v configuration - its what most of us do as this operates nicely with most 48v equipment - giving you the broadest set of options for charge controllers, inverters, BMSs, and just 48v equipment in general.
Yes you can mix them.    You want to test them before making a distribution.   You might find that the 4000mah only have 3600mah (e.g. 90% of original capacity) and the 3600mah have 3600ah (100% of original capacity).  After test -  I would distribute them evenly by capacity (in 100mah increments) and manufacturer as reasonable - its OK if things are not perfect.    You want each of the 14s packs to have the same ah(s) as reasonably as you can - with the different brands distributed as is reasonable.
If you have 923wh of cells, then you should have around 65 cells.   5p cells per pack * 14s would be 70cells.    If each pack averages  5cells in parallel * 3800mah each on average then you have 19,000mah (@3.7v) in each pack.    If you could get the 14 packs so the largest delta is within 400mah or less (e.g. <= 2% of a pack's capacity) you should have a perfectly manageable 14s battery for a typical Solar charge/discharge profile. If the battery must deliver high current such as a motorized 'something' then it get's more critical to keep it tight.
My own packs are 130ah to 133ah - 2% difference - in a solar application and they stay balanced with no effort.
Of course you need to look into a BMS as well.
I wanna mix my cells too but not using the fixed number per pack
"Arrange cells in to packs so each have similar capacity but vary the number of cells in parallel and keep cells in a pack roughly the same capacity"   don't work for me
for example, 2 series return 1 pack only.
all tests I tried goes wrong using this option
You should have same amount of cells in each pack. Make sure to sort Them evenly and by statistiska in terms of brands and AGE and that Will work out the best.
Having different amount of cells just makes it more complicated to get even current on each cell
Korishan likes this post
Agreed with Daromer. Same number of cells per pack. This is for amp balancing. If 1 pack is 10 cells, and the other is 15 cells, then 10 cell pack with see a 50% increase in amps per cell.
20A load
20 / 10 = 2A/cell
15 / 10 = 1.5A/cell
This will not only stress the low cell count packs more, thereby reducing their overall life cycle, but it also makes it so that you need heavier gauge wire on that pack and you're risking popping fuses on that pack (if you use fuses, which is advisable)
(04-22-2020, 01:45 AM)LC-2nd Wrote: for example, 2 series return 1 pack only.
Please clarify this statement. This doesn't make any sense.
bogptrsn likes this post
(04-22-2020, 12:31 PM)Korishan Wrote: Agreed with Daromer. Same number of cells per pack. This is for amp balancing. If 1 pack is 10 cells, and the other is 15 cells, then 10 cell pack with see a 50% increase in amps per cell.
20A load
20 / 10 = 2A/cell
15 / 10 = 1.5A/cell
I guess repacker have some bugs in the variable number cells option
I tryed many times and nothing goes right.
using cells of 20A for tests, more problems. repacker ignore em all (ok, no cell have 20A but I tried it also)
I wanna make small packs of used 18650. modular system. maybe each with 30A. if one goes bad it's easy to find the problem or replace it. used cells = many with different amperage and I wanna use em all. and I know the risk of some goes bad in the future.
please, just test repacker with variable number of cells. here in my PC the results are a nosense
20A load
20 / 10 = 2A/cell
15 / 10 = 1.5A/cell
Do you mean...
20A / 15 cells = 1.3rA /cell
20A / 10 cells = 2A / cell
If you use the 21700 in the smaller count packs, that would balance out somewhat.
As at Mid May 2020 -Total cells 1,135/Shucked 1,045/To be shucked 90/Processed 194/To be processed 608/Zero volt 183/Bad/rusted 19/Sanyos 1/21700s 24
All tool batteries comprising of Milwaukee, Makita, AEG, Hilti, with Samsung, LG, Sony and Sanyo cells from 1.3AH to 3.0AH (OEM)
Chargers... 1 x Nitecore D4/1 x LiitoKala 500/1 x iMAax B6AC
On order... 5 x LiitoKala 500/1 x LiitoKala 500/1 x iCharger 4010 Duo
