Hi All,
I am listing these for someone who has a bunch of these for sale from a cancelled project.
As you probably know, Voltronic is the actual manufacturer of inverters like MPP Solar, Growatt plus about 40 other incarnations.
These items are in the UK, the asking price is 340, discount available for multiple units.
Due to pandemic lockdown, payment by BACs would be necessary, items will be shipped by courier for 10.
These are brand new in the box, specs taken from the Voltronic website:
Voltronic Axpert II 3000-24 Off-Grid Inverter
Rated Power: 3000 W
Voltage: 230 VAC
Frequency Range: 50/60Hz (Auto Sensing)
Surge Power: 6000 VA
Efficiency Peak: 90%~93%
Waveform: Pure Sine Wave
Battery Voltage: 24 VDC
Floating Charge Voltage: 27 VDC
Over Charge Protection: 33 VDC
Solar Charger Type: MPPT
Maximum PV Array Open Circuit Voltage: 500 VDC
Maximum PV Array Power: 4000 W
MPPT Range @ Operating Voltage: 120 VDC ~ 450 VDC
Maximum Solar Charge Current: 80 A
Maximum AC Charge Current: 60 A
Maximum Charging Current: 80 A
Dimensions: 100 x 300 x 440 (Depth, Width, Height)
Weight: 9 Kg
Communication Port: USB, RS232
Operating Humidity: 5% to 95% Relative Humidity (non-condensing)
Operating Temperature: -10 Degs Centigrade to 50 Degs Centigrade
Rated Power: 3000 W
Voltage: 230 VAC
Weight: 9 Kg
