NERDVille
New member
- Joined
- Oct 9, 2016
- Messages
- 23
Hi All
So I'm gathering components to build the BFC and wanted to get some advice regarding the circuit layout for hooking up the TP4056 modules
I'm considering using a 1.5A resettable Polyfuse should the TP4056 chip decide to drive itself above 1.5A its got some protection.
Is it worth putting in a capacitor inline to stabilize current from the PSU too?
AND does it matter if these are soldered on the negative or positive side of the holder.
But, what about when inserting batteries in the wrong way. I know I need a Diode but what spec would be cheapest and type?. Zener? Rectifier? Solid State?SCHOTTKY BARRIER DIODE? etc :huh:
If you think there is anything else adding worth adding please feel free to suggest and advice.
thanks
NERDVille
thanks
NERDVille
