anyone used these cells for a house powerwall
Hello,  just wondering if anyones used these type of cells from aliexpress and to know your experience so far. im planning on a sofar me3000sp inverter charger so is it likely 16 of these in series will give the full 3000watts out the inverter ?
heres a link to the type of cell im refering to
many thanks
https://www.aliexpress.com/item/40001084...4673b404c0
(05-01-2020, 07:42 PM)motofox Wrote: Hello,  just wondering if anyones used these type of cells from aliexpress and to know your experience so far. im planning on a sofar me3000sp inverter charger so is it likely 16 of these in series will give the full 3000watts out the inverter ?
many thanks
16s LifePO4 cells make a good (standard) 48v nominal battery.  The ME3000SP specs say "Battery Type   Lead-acid,Lithium-ion" - so I'd recommend affirmatively checking to make sure its either supported or you can customize the voltage settings.   In general, a 16s LifePO4 battery will have a very similar voltage range as a 14s Lithium-ion - but still, its worth checking since they choose to leave it out of their description.
Wrong section. This does not belong in Projects section.
Belongs in Cell Discussion section. Moved to proper location
