Hi All, i have around 80 lipo pouch cells.actually 80x2 as while harvesting them from old laptops they were already 2xparellel and i found it easier to take them out in pairs. however for simplicity lets refer to them as 1 cell.
They have been sitting with we for a while as i didn't know how to handle them. there is lot of info on this forum and other places on using the 18650 form factor, there is hardly any on pouch cells. However recently due to the covid situation i have some spare time and i decide to work on them. I have started soldering wires on the positive and negative terminals as you can see in the second pic.
my plan is to have 4s20p. i am struggling on how to do the wiring, should i use nickel or a bare copper cable and solder the other end of wire from the battery? if so how do i insulate it. or should i use a terminal connector strip and screw the wires each. also any ideas around what kind of case i can use or create.
i want to have a 12v 80ah battery pack with some 4s bms that i have not researched on yet. Also i am not sure how i will be using this battery. most likely i will pair it with an inverter an use as a backup power.I am taking it step by step and the first thing i am trying to figure out is how to create this 4s20p battery.
Thanks for your help in advance,
Mike
Mike
