hey guys is there al list of fault codes for the inverters? i have the hybrid v2 5048 version and is flashes a code on the display [6P] with a triangle with questionmark
(coincidence with your name!)....I also have an MPPSolar PIP - the fault codes are in the user manual. I can post a screenshot of the right page if you don't have a copy to hand......
Hope this helps....
Hope this helps....
