Strange 18650 capacity test
(05-14-2020, 12:03 AM)Yiğit Wrote: ..................can you explain 4 wire discharging method in my charger there is 2 3 4 5 6 s balance sockets..........
2 Wires for load and 2 wires for balance.
The 2 load wires will have a voltage drop on them so you will not have the proper V reading.
The 2 balance wires do not have a load on them so their actual voltage is correct.
Yiğit likes this post
Correct... you want to use a JST connection (typical balance lead) with just 2 wires on it (1s).  2 for the load, 2 for the measurement.
Its useful in multiple ways...
Overvolting wont lower the amp draw unless the controller works based on wattage.
Higher voltage also increase current due to u=i*r.
The balance leads will then act as voltage meassurement. If you use original wires for the charge/discharge port they are very thin and have resistance inside causing voltage drop. Those 4 together creates the 4 wire testing.
2 is for drawing current in or out and the 2 from the balance socket are there to meassure voltage. Suddenly you get alot better reliable results.
Crimp Daddy and Yiğit like this post
I actually learned this from daromer... and after implementing this on all my balance chargers, my termination voltages are pretty much spot on. It helps a lot.
İmax doesn't have 1s balance lead it seems
And when i measure with multimeter voltage difference is 0.05 volts max
Use a 2 cell plug but only use 2 of the connections and that should give you the results you need.
I connected the balance cables to the battery terminals with the other red and black cables.
When i open voltage meter on imax it shows voltage correct, in balance screen , but when it comes to discharge imax says no battery found.
I have to ask.
Are the main leads hooked up to the battery and is there an option for 1s in the setup?
You can select 1s from imax but there is no balance cable for 1s, only for 2 3 4 5 and 6s balance
(05-14-2020, 01:41 PM)Yiğit Wrote: You can select 1s from imax but there is no balance cable for 1s, only for 2 3 4 5 and 6s balance
Yes you have to make your own balance cable or just use the neg and first pos from the 2s cable.
Remember most people would never "balance" a 1s so the cable is not included but for a proper V reading on a 1s you need to have that connection.
