16s BMS advise
#31
(07-04-2020, 12:58 AM)OffGridInTheCity Wrote:
(07-03-2020, 07:40 PM)Doin it Wrote: With the chargery that is 2 separate units,, can it be used to only monitor cells and not balance? Later as the cells degrades I’d want to balance.
They make 2 different models.  The 2 unit model does protection+balancing and the single unit (with display built in) only does protection but no balance.
Is it ok-easily possible to use the 2 unit model to only monitor, no protection or balancing for now?
#32
Sure.
- You set balancing option in the menu and balance is 'off' for STORAGE mode (no charge or discharge amps on the shunt) bu default.   Don't hookup the shunt and it will be in STORAGE mode all the time and then balance can be off all the time.
- An external relay is required turn the load on/off (e.g. give protection) so don't hook up the relay
Doin it likes this post
