hermitdave
Member
- Joined
- Aug 12, 2018
- Messages
- 254
hermitdave said:Thank you @Sean
Ill try G59 first?
Many thankschuckp said:hermitdave said:Thank you @Sean
Ill try G59 first?
Hi bud
It relates to your PV size and connection type, most residential is under 4kWp and can be connected under G83. If over 4kWp then it would have been connected under G59 and required a DNO application approval, they would have come out and inspected the local grid power lines to confirm that it can handle your potential export.
That was what I had to do due to having a 7kWp system.
