PV phase 1 complete
I managed to install 4x 250w secondlife panels earlier this week and wired the Growatt 1500s yesterday.
Considering it was very miserable for most of the day, it was good to see it generating enough for background usage for an hour today
The router is mounted on external wall and I added WiFi module for monitoring.
Next phase PV diverter using Mk2PVRouter. Has anyone played with it?
Wolf, Redpacket, chuckp And 1 others like this post
Pics of the PV panels, brackets, mounts, and base/anchor please?
Using Clenergy univeral roof brackets - the company i used also have easy mount rail but i decided to reuse original rail that came with the panels.
The original rail
The mid / end clamp
The mounted panels
Top view
The inverter
When going the 4th and last panel I realised that panels were at a slight angle. Will fix that at later date
I purchased the mounting brackets, mid / end clamps, crimped cables, inverter and wifi module from TripleSolar UK. Very helpful lot.
ajw22 and OffGridInTheCity like this post
Nice install!
Yes sir, I have a (cement) tile roof and used similar roof mounting brackets (Solar Roof Hooks) -> Ironridge rails.    The multi-hole plate is important so you can offset (left or right) to the studs to keep it from hitting the tile to the side.     Here's a 2m video showing how they install - its doable by DIY Smile       https://youtu.be/q1UMd96WE8c
(06-12-2020, 02:52 PM)OffGridInTheCity Wrote: Nice install!
I used angle grinder like you did on the latter tiles. For the top row I tried to use a tile file.
I might pull them out and redo them in coming months as we are discussing small extension over that roof ?
The joist screws from my supplier were a bit better
I was advised (and used) these. The other big tip was to screw them in at an angle from both sides of where you think the stud is (instead of 'straight down')...  and this increases the chance you'll find the stud.  This tip worked really well for me Smile
I felt the joists under the felt and adjusted the brackets correctly.
It feels good seeing it work. Sure so far it has only generated enough to power dishwasher but better that than nothing right?
chuckp and OffGridInTheCity like this post
