High current tester modding
Did anyone attempt to mod a tester like the Lii500 or Opus or anything like that to make it support higher discharge test current, like 2A or even more ?
Most of the chargers on the market only test on all slots at 0.5A; Opus needs extra cooling for 1A  across all slots.
It would be nice to be able to mod them.
Any thoughts ?
What would happen if we would replace the discharge resistor with another to allow higher current ?
Could it work on any of the currently available chargers or is that a too complex matter to to other charger internal construction limitations ?
Its easier to just buy a high current tester to be honest. Like the ZBl3 or what not.
ZB2L3 is not currently available anywhere near me (as in my country).
Guess I could build a multi-slot out of these, but I'd prefer something already manufactured for now.
Hook up several Ichargers then Smile Then you can get up to 40A testing current per cell Wink Or run the duo and get 70A Wink
it would be very difficult to modify the opus or liitokala to do higher amp discharge because of the programming and circuitry and traces. It was designed with 1A in mind and trying to modify it could make it act all wonky.
It would be much easier and probably far more accurate to use an MCU (arduino or such) to toggle a relay to a load and count how long it takes for the voltage go from A to B.
You can test cells at 4 Amps Discharge on the Opus. Take 3 dummy cells (CID cells are great for this), put electrical tape on the terminals of the cells, and then use a busbar or nickel strip on the top terminal (positive) of the Opus along with the cell you are testing. The Opus will think it is 4 cells and do a 1 Amp discharge on each slot. Somehow, they are all isolated. If you get 500mAh per slot, that means the battery capacity is 2,000 mAh @ 4 Amps. Credit to OffGridInTheCity for this one!
That's kind of a nice cheat if it works, Generic.
