REC Precharge, Batrium, EV200AAANA CONTACTOR
I need help Connecting (integrating?) A Rec precharge to my Batrium System.
I have read this page from Batrium
Wiring a Contactor to On-Board Output on the WatchMon Supervisor
But my install is done except for this last bit, and I dont want to mess this up. Do Output A and P go into the Precharger?
What is a rec-precharge? A 4second delay? You dont need any delay with Batrium. In Batrium you can set delays.
Not sure what your goal is here? Please explain.
(06-18-2020, 05:50 AM)daromer Wrote: What is a rec-precharge?  A 4second delay?  You dont need any delay with Batrium. In Batrium you can set delays.
Ok I thought I need a pre-charge to use with a Contactor? For the "inrush"
Ahh yes you cannot connect the contactor if its to big directly to batrium
I use either external relay or an resistor in series with the contactor. The Rec precharge should work to since its basically above Smile
(06-18-2020, 09:05 AM)daromer Wrote: Ahh yes you cannot connect the contactor if its to big directly to batrium
I was trying was wondering how to connect the REC Pre-charger to the Batrium.
