The batteries in question are these https://www.batteryclearinghouse.co...26659m1b-lifep04-3-3v-2500mah-in-10-emc-packs out of the ten batteries I bought 6 were 26.6v 3 were between 27v and 27.4v.
I managed to harvest 8 cells from one battery. The 8 cells are at 3.33v. The Cells are soldered to the bms board. not much room to work . After my thumb deciding a nickel strip was a perfect landing spot i decided to ask if there is an easy way to harvest the cells.
later floyd
later floyd
