Charger 1Ah Battery Temp
Hi All,
Me again, trying to absorve as much as I can....
Im charging a battery at 1Amh (Theorically) maybe is getting a bit less than that, and Im getting Temp readings with my temp gun of 47C degrees = 116.6F degrees
What is the acceptable max degrees per cell... allowed .. cell is a Samsung ICR....26F
Thanks is advanced.
CG
Based in Panama
PV = 3 x 200W
Bat = GEL 250Ah
Going on-grid
** 333 ** batteries harvested / getting GTILv2 1Kw auto sense 22-65V
You are charging with 1A. A= current. Ah = Capacity.
How are you charging it? In an Opus? I wouldnt state 47C is overly warm but its for sure in the top end.
How much capacity do that cell have left?
(06-22-2020, 05:39 PM)daromer Wrote: You are charging with 1A.  A= current. Ah = Capacity.
charging at 1000 mah
using LiitoKala
some 44C and some 47C at the moment
CG
Based in Panama
PV = 3 x 200W
Bat = GEL 250Ah
Going on-grid
You still dont charge with "Ah/mAh". Its A or mA....
I dont think the temperature is an issue as long as they perform capacity wise.
using LiitoKala
CG
1000ma
Thanks for your reply
Based in Panama
PV = 3 x 200W
Bat = GEL 250Ah
Going on-grid
