ESP32 help
Do any of you know somebody familiar with ESP32 dev boards? I'm trying to get data from my 'Smart' Chinese BMS. I have the ESP32 but have no idea how to make this work.
Seattle, USA
14S120P 48V battery - Magnum PAE4048 inverter/charger - MidNite Solar Kid MPPT - 1.4KW Solaria panels
Where are you stuck? What have you done? How have you wired it up?
I would say this is not really about esp32 as such since you will most likely do the same thing on arduino bords, esp8266 or others if you use same code.
Arduino IDE?
As daromer said what are you trying to do ?
Get data from a cheap chinese BMS. We got that.
 What is the BMS model what does it have for outputs or interfaces. WIFI, Bluetooth, TCP, UDP, Modbus, Canbus, Serial?
Where do you want the data to go? Influx, Mqtt, SQL Node-red, Cloud?
How do you want to visualize this data excel, grafana, web dashboard, phone app?
Questions that need answers so we can answer your question.  Smile
BMS currently has a bluetooth communication dongle. I'm looking to swap that out with wifi capabilities of my ESP32 dev board. I researched the following three github apps:
https://github.com/CRaccani/smart-BMS-NodeMCU
https://github.com/tomcosk/BMSBatteryMonitor
https://github.com/simat/BatteryMonitor
Presumably, if I get one of these running on my ESP32, I will be able to at least monitor the info via a web page on my home network? CRaccini seems to have control capabilities which would be awesome!
Seattle, USA
With ESP32, you can't use BT and WiFi at the same time. The only way you could do this is to (rapidly) switch back and forth between connection types. This is a lot of overhead and will be prone to bugs and dropped packets on either radio.
(06-25-2020, 03:13 AM)Korishan Wrote: With ESP32, you can't use BT and WiFi at the same time. The only way you could do this is to (rapidly) switch back and forth between connection types. This is a lot of overhead and will be prone to bugs and dropped packets on either radio.
I don't want to use bluetooth anymore, since it requires me to be in the shed with my batteries.
Seattle, USA
I thought you were gonna try to use BT to communicate with the BMS and then WiFi to send it out.
Are you trying to hardwire the EPS32 into the bms?
And how much have you done?
Connection? Code?
Or do you expect us to do the work for you?
(06-24-2020, 07:35 PM)Sleonard2649 Wrote: .............I researched the following three github apps:
Presumably, if I get one of these running on my ESP32, ..........................CRaccini seems to have control capabilities which would be awesome!
CRaccani solution was portet from mega256 to esp8266 not esp32.
tomcosk solution involves a linux box or a raspi.
simat solution is on a beaglebone or another linux platform
Guess you are gonna have to start from scratch.
Personally I would use the (noble)bluetooth palette in node-red to see if you can communicate with the BMS. If that works grab the decode info from simat and get busy. Wont need an esp32 just a raspi............
ESP8266 almost work out of the box on esp32. You dont need to do that big changes unless the libraries used only exist on one place. Then you have to redo some smaller code.
