SolarPowerWall (Germany)
hi,
long time passive reader, now its time to say hello...
working with electronics and computers since 1982, build my first offgrid solar 1986.
some pictures of my project, 1/2 finished:
400w 72cell solar
epever xtra4415
smartbms 6s + esp8266 webserver/mqtt for smarthome integration
480cells (same type, same source, 95%)
cheers
iDIYot
safety first, packs are spotwelded, single fused, fr4 covered, 1.5mm steel housing
bms dinrail holder & cell cleaner/grinder
https://www.thingiverse.com/idiyot/designs
cheers
iDIYot
Korishan, ajw22, OffGridInTheCity like this post
Very nice looking, but be aware that this design is not suitable for high current usage... perhaps sustained max of 10A~20A(*1) 20A~30A.  All the current has to pass through the areas marked in red, which at the narrowest point probably has only about 3.15mm^2 cross section (guessing 7mm wide x 0.15mm thick x 3 bridges).  A copper wire soldered along the orange line would help a lot.
(*1) Just looked up the electrical resistivity of nickel (4x that of copper) and steel (8x ~ 40x that of copper).
https://en.wikipedia.org/wiki/Electrical..._materials
2 busbars per area 6mm² each are prepared for soldering, test current was less than 10a...
thanks
iDIYot
ajw22 likes this post
Most interesting way of connecting the cells.
Hope that type of connection provides sufficient current.
6s folded (u-form)
load 80-120w (home server & cctv+ir)
current should not be an issue...
iDIYot
