Solderless Powerwall Project - Simplest & Cheapest Design?
Hi!
I'm new here and am excitedly embarking on my first 18650 powerwall build in eastern WV. I'm seeking help, advice, tips; it'd be amazing to find someone near Washington DC who could help me in person with this build. I'm building a 24V system; then scaling up to 48V once I've sharpened my skills.
I'm going for cheap, simple, quick and easy so that I can scale this up and help rural impoverished communities get powered up; that's why I love the idea of using copper pipe as bus bars (even if they are not 100% ideal), and making the enclosure out of foam board or MDF or plywood.
I bought 1,554 18650 modem batteries from batteryhookup that are still in their original packaging; could the holder that they are in be of any use for my build?
I've familiarized myself thoroughly with all of the other available solderless TEKS which I've found, and still I'm most interested in the design in this video for it's elegant simplicity and cost. I think this TEK could open the door for many diyers who can not solder, or afford one of the solderless systems on the market.
Since this is my first post apparently I can not add a URL, so please search for this vid on the "SocialHack" channel on youtube: 18650 SOLDERLESS POWERWALL PARTS
The innovator in this vid says he has built large systems successfully that have been operational for years without fail. He seems to have disappeared from the scene though, his patreon page is inactive so I wonder if this is any cause for concern, or if he simply felt he provided the diyer with all that they need and therefore considered his mission completed.
I want to build this asap so ordering parts from China isn't really an option for now.
As you can see from this video there are a few different ways to make this powerwall; I am going for the simplest yet safest option available.
I'm still a bit confused as to exactly what parts I need and if a BMS is required. My understanding is that the BMS is often the part which fails and can cause fires.
The LED indicators on this powerwall would indicate if a battery has failed so that it can be easily replaced; and the fusing system seems like it would provide ample safety. Some of the parts shown just seem not heavy duty enough for this application but I'm not certain of that. And I wonder if the USB parts are necessary; I do understand that it serves as a battery charger; perhaps I'm not clear on why this is 100% needed. It seems like there is a way to simplify this design even more.
Thanks in advance and be well Smile
As you mention, there are several approaches and many details to building a battery from 1,554 cells - but it is fun!
Let me tackle a few items, and I'm sure you'll get additional posts.
Solder vs Solderless
There is a 3rd option - which is spot-weld.  I'll assume by solderless you mean things like PCBs with holders where you push/pop in/out the cells but don't solder or spot-weld.  This idea has it's attraction but the economies of scale kill you.  When it's a matter of 100 cells then an extra xx cents/cell is no big deal but when it get's to be 1,000(s) of cells...  then the extra cents per cell turn in to hundreds of dollars.    You should always do your own math/thinking - but you probably find its cheaper to solder/spot-weld than buy printed circuit solutions or solderless solutions.
When I build a 1s100p pack I solder and use....
- 16 x 4x5 cell holders =  $0.60c * 16 = $9.50    ( I do 100-120p but will hold up to 160p )
- 4 x 28" 6awg twisted copper bus bars @ 0.59c/foot = $5.50
- 4 x Lugs = $3.00
- Solder - maybe $3.71
- Fuse wire / tinned copper wire (cell -> busbar) - maybe $3.00?
- 2 x Hot Glue sticks + 6 14" twist ties ~= $1.00??
That adds up $25.71/pack in raw material * 7 = $180 for a 7s  battery.  I have 84 packs - so you can see that 84 *25.71 = $2159.64 in 'just pack build materials'.  It really adds up as you scale Smile.    That's why I say, just do the math and see what's good for your situation.
If you use spot-weld you'll need a spot-welder + nickle strips in addition to the above but you'll use much less solder and won't need the fuse/tinned wire - so I think it'll turn out to be 'in the ball park' of the solder route if you do enough cells to pay for the spot-welder.
Yes, you need a BMS.   A BMS as a minimum protects against over-voltage and under-voltage / pack(cell).  Typically it will also protect based on temperature.  Typically it will offer balancing as well.   The key thing is to shut off power going in (charge) or power coming out (discharge) from the battery if any one of the packs(cells) in series get out of the proper voltage range and/or temperature range to protect the cells.  In particular, if you allow an 18650 cells to overcharge for any significant amount or time it will result in a fire and each cell is likely to ignite the cell next to it - very big deal.   If you let the battery go too low a packs(cell) in series can go negative causing the pack to take current in reverse which does severe damage - and again we're back to fire risk - a very big deal.
A base BMS will have leads (small size wire) to connect to each pack in series so it can monitor/track the voltage.  These same leads can be used to balance the packs relative to each other if the BMS has a balance feature.  A lot of BMSs have a balance feature but not all.   A BMS will typically have a way to mesure the temperature of the battery - should include some temp probes.  A BMS will have some way - either internal relay or you have to buy an external relay - to shut off power flowing in/out of the overall battery.   Finally, a more expensive BMS may have a bluetooth -> android phone app or a screen so you can see what its doing / set various parameters.
There are many youtubes on BMSs...   Here's 3 from the same person to give you an idea of the range of simpler/cheaper BMSs...
Here's a youtube on a base BMS to give you an idea..  (its for LifePo4 but info applies to Lithium-ion)...  https://youtu.be/bj7abaCrwvI
Here's a youtube on a more expensive one with it's own screen ...  https://youtu.be/RfAv6kzebYY
Here's a youtube on a phone based BMS...  https://youtu.be/im4ggvoni5M
If you buy a BMS with visual monitoring - that is a common way to know if the battery is healthy - e.g. check the BMS status.
For the dirt-cheap / LED solution - you can buy an LED (or even a cheap volt meter) and power it by the output of your battery (down stream from the BMS) and if the BMS trips the LED will go out.  Of course the LED will drain power the entire time its on so you might want to add a switch so you can turn the switch on to check the LED when you're looking and then back off to avoid power drain when you're not looking Smile.
SolderlessSouldier and hbpowerwall like this post
