Cell Level Fusing w/ 24AWG TCW
Hello, I have been having issues properly affixing 30AWG tinned copper wire to positive cell terminals. I am using a kweld to spot weld the fuse wire to the cell and it has been incredibly hit or miss in terms of making a proper weld. I am not satisfied and will not be continuing with using Remington 30AWG TCW.
I have decided to use 24AWG tinned copper wire connecting the copper busbars to the cells. These have been welding very securely.
My powerwall is 14s168p with brand new Panasonic cells. I have read the sticky threads in the FAQ on cell level fusing and understand should a cell short, the remaining 167 cells will all force current into the shorted cell.
My question is:
1. Given that if a cell shorts, and the other parallel 167 cells all force current into the shorted cell, this current would easily exceed the ~20A blow point of the 24 AWG wire. Am I wrong in thinking that this wire will be alright to use?
I'd greatly appreciate feedback regarding my use of 24AWG as fuse wire. Thanks!
Increasing the "fuse" blow point is also increasing stresses on the pack. Altho, if the wire pops at 20A, that should still be sufficient.
However, if a cell is partially dead shorting itself, and only pulling 10A from the pack and dumping as heat, the 24awg will not blow.
Remember, not all cells go full on dead short when they die. The can go through a phase of increasing self discharge until they go full short.
Personally, I wouldn't go with 24awg. It's a bit too thick and too high amps needed to pop it, imho
OffGridHawaii likes this post
(07-31-2020, 01:24 AM)Korishan Wrote: Increasing the "fuse" blow point is also increasing stresses on the pack. Altho, if the wire pops at 20A, that should still be sufficient.
Thank you. Do you have experience using a kweld spot welding TCW to cells? It was not working properly for me with the 30AWG. Do you think somewhere between 24-30awg would work better and be safe enough?
I haven't done any spot welding, so no experience with that.
When you say it wasn't working properly, what problems are you having? Is it blowing through the wire; not welding to the cap; sparking too much; etc?
Just a comment for you to take or leave Smile
I believe the goal of cell fusing to be a rapid melt (<1sec) as apposed to a 3,4,7sec heat-up/drip/melt.    I use 30AWG for my fuses and my (unscientific) tests + youtube lurking (like @AveRageJoe fuse wire tests such as this one on 30AWG - https://youtu.be/eBn3nAnh7fs) indicate more of a 15a range before melting 'rapidly'
I use 27AWG for my negative side -> bus and its thinner than 24AWG but yet takes noticeably more amps than 30AWG to melt rapidly as I've occasionally shorted it while building a pack.
Because of the above - I would suggest a double-check that 24AWG will not melt 'rapidly' at 20a .
On a positive note - if you do find that 24AWG is not OK, and 30AWG won't spotweld - one solution might be to use those fast-blow axial fuses - that you can get in specific amps.  The leads on those will likely spotweld OK.
OffGridHawaii, 507PowerWall, Korishan like this post
Thank you for your feedback. In regard to problems spot welding 30AWG, it's incredibly cumbersome, it sparks 75% of the time, and it blows through the wire making a very weak connection at all power settings. I don't feel safe going forward spot welding that wire. However spot welding is the only method I am going to use to avoid overheating the cells.
I actually started off using 2amp glass axial fuses and needed to stop that quickly as well. Using those is extremely cumbersome. They weld okay but the angles involved don't always match up properly and I feel do not make a structurally safe pack. I have also read that these have quite a lot of resistance.
______________
Considering I have brand new Panasonic cells, I am hoping this will minimize the risk of a cell failure. Would monitoring the packs with an IR gun periodically be a good way to monitor the packs for slowly self discharging cells?
Correct me if I'm wrong, the risk of using 24awg fuse wire would be if a cell started slowly discharging, all of the other cells in parallel would work harder to equalize, and this stresses the other cells.
*Would this take place for a while where I could monitor and see the cell, or is it a rapid escalation?
*Would 24awg prevent a runaway event?
*Would you mind explaining/pointing me in the direction of understanding a dangerous runaway event? This is what I want to avoid happening. I apologize if this has been hashed out and would appreciate links/reiteration (the search feature on this site can be difficult to navigate sometimes). I'd appreciate understanding the chain of events for catastrophic failures.
I apologize for a redundant post but I'm hoping bumping this thread might give me some closure on this topic. Would someone mind chiming in on:
One of the main ways to initiate a 'runaway event' (in my mind) is to overcharge cells.  See 3:15'ish of this youtube and the aftremath - it can be horrific..  https://youtu.be/WdDi1haA71Q    Overcharge is not likely with BMS.
The next way (besides overcharge) is due to cell damage internally for various reasons - and dendrites form / a short forms.   I've not actually seen a video or anything showing this happen but I understand that this can lead to fire...  which can lead to the video above.
TOPIC1: Protect the pack from a dead-short - this is the goal...
The problem with 24AWG is it not typically used that I've read...  so I don't see people saying 'yea it works'.   But its you're powerwall and your decision.  If I was dead set on 24AWG then I would do some experiments to verify it burns thru quickly.   You can simulate a dead short with the pack.   If it does, without bad side-affects (like meltng metal running down a cell) then you may be satisfied.
You dismissed axial glass fuses..
Another alternative for spot-weld are nickle strips (with fusing) like this - https://batteryhookup.com/collections/ce...ickel-fuse    BatteryHookup says they'll be back in stock soon.  @HBPowerwall just did a fantastic youtube on using nickle strips to build a powerwall -  https://youtu.be/PenPYwa00CA
TOPIC2: Self-Discharging Cells/Packs...
You don't need to mix self discharging cells with the topic above.  This is not catastrophic with proper BMS to alert you that a pack is bad.   The BMS voltage monitoring  will make packs with self-discharge visible because they will lag behind the other packs / cause balancing requirements.   These should be fixed as a matter of regular monitor/maintenance.  I don't imagine a healthy pack will degenerate into a 'self-discharge fire' unless you let it go for weeks/months and balance failed and BMS let it go below minimum voltage.  Long before that you should fix the pack Smile
RECAP:
Fire risk is from overcharge + using damaged cells.  Cells get damaged physically or by draining too low or charging too high or by temperature....    and perhaps in very small % - bad manufacture.     Fusing is a strongly suggested idea for DIY powerwalls (e.g. large packs) which is shy Tesla create/uses this in their EV batteries.
P.S. You mention your 'cells are new'...  but or course as soon as you charge/discharge them 50 times they are no longer new.  That's the problem with cells - they do not remain new Smile
OK - that's my 2 cents from what I've read, seen and how I think about it with my own 80kwh battery bank.   But please, of course, make your decisions Smile
507PowerWall likes this post
(08-02-2020, 09:50 PM)OffGridInTheCity Wrote: One of the main ways to initiate a 'runaway event' (in my mind) is to overcharge cells.  See 3:15'ish of this youtube and the aftremath - it can be horrific..  https://youtu.be/WdDi1haA71Q    Overcharge is not likely with BMS.
Amazing video. Definitely want to avoid that! I am charging to a total of 4.0 volts per pack (56) and managing the battery with a Batrium BMS, hopefully I can avoid this with those precautions.
I've strongly considered these, I'm a bit concerned though because they have an iron core and I live in a humid tropical environment near the ocean. I'm very concerned they would rust out quickly. I'd really like to give them a try at some point.
Excellent, batrium should be very helpful.
RECAP:
Thank you so much, incredibly informative. I decided to order some 28AWG tinned copper wire to compromise a bit and see if I can get it to bond better than the 30. Aloha.
m4dmike likes this post
