Are peacefully died cells inactive and safe?
Hi folks,
i am trying to reengineer 10s6p blocks (bikeblocks) down to 7s6p by reconnecting them. Reason is i need a few 7s Blocks, and i have a couple of 10sxp blocks with 1 or 2 dead stages.
Question,
Is it necessary to remove all unused cells ( which is devilish task) instead of just disconnecting them an letting them die down by themselves ?
btw, interesting is that the died stages all hat one blown cell, with has sourced the others down in oblivion (of that stage), no chance to revive them.
i removed the blown cell just for un-smelling the block, its a hazzle.
Can i assume the disconnected ones will stay shut, or is the experience they will make problems in future ?
Thanks in advance.
1 kWp in Test
Ultra low cost
Cells which have been <1V for a while typically get sent to recycling.
This is due to the risk of copper crystals growing later & making a short circuit > fire.
Extremely overdischarged cells (< 1.5V) are generally considered to be safe only if they are never charged again (charging can cause dissolved copper to replate into dendrites, which may lead to internal shorts at some future date).
So assuming you have the skills to electrically isolate the bad packs and properly rewire it then you should be fine.  Be sure to update to a proper 7S BMS.
(08-01-2020, 03:27 PM)Redpacket Wrote: Cells which have been <1V for a while typically get sent to recycling.
Hi,
Most of the cells are <2 V already, or will be by themselves soon.
So, no fire. I just ask if they will be leaking...
(08-01-2020, 04:09 PM)gauss163 Wrote: Extremely overdischarged cells (< 1.5V) are generally considered to be safe only if they are never charged again (charging can cause dissolved copper to replate into dendrites, which may lead to internal shorts at some future date).
thanks.
1 kWp in Test
Ultra low cost
A lot of the time "dead" cells are not actually dead especially if you are harvesting the out of laptops. Most of the time the dead cell is just running a very low voltage that your charger will throw an error and not charge it. What i generally do is have a single charged cell in a holder and place the wires in parallel over the dead cell for about 15 seconds to bring up its base voltage then put it in the Opus and they are usually good to go and fairly decent cells.
Have been finding that doing this im saving about 50% of dead cells which are not actually dead
^^^ That's a dangerous thing to do in general. First, if the cell is extremely overdischarged (generally < 1.5V) it should never be charged again (see post #2).  Second, if it is between 1.5V and 3.0V then it needs to be precharged at low current (< C/10) to allow the crucial (possibly dissolved) SEI passivation layer to properly reform. The low current also allows the cell to be safely monitored for internal shorts. If precharge doesn't reach 3.0V in a short time (< 30 mins) then the cell likely has an internal short so it should be discarded. But you are fast charging it at high current when charging it with another cell - exactly the opposite of what is desired.
(08-02-2020, 02:24 AM)Mitch Wrote: A lot of the time "dead" cells are not actually dead especially if you are harvesting the out of laptops. Most of the time the dead cell is just running a very low voltage that your charger will throw an error and not charge it. What i generally do is have a single charged cell in a holder and place the wires in parallel over the dead cell for about 15 seconds to bring up its base voltage then put it in the Opus and they are usually good to go and fairly decent cells.
Check the voltage of the cells with a multimeter before attempting to start charging them.
As posted above cells with low voltage < 1.5V can be a serious problem later.
Cells in the range approx 1.5V to 3V should be charged at low current eg 50mA until over approx 3V then normally charged.
"Jump starting" with another cell might work but isn't the recommended way to do it.
