OffGridInTheCity said:
A while back, I processed several hundred[...] medical packs. Many were 0v/lowv - and [...] I was able to recover a majority of them to be able tocharge up in my OPUSs- however - many of them got HOT (e.g. too hot to touch) and had to toss them.
Safety warning: generally manufacturers warn to
not charge extremely overdischarged Li-ion cells, i.e. cells <1.5V, eg. 0V, (though some use a lower 1.0V threshold). Charging can lead to serious safety problems (briefly: copper can dissolve at low voltages and then during charge replate into dendrites, possibly leading to dangerous internal shorts at some future time - often without any warning). For some very old cells (lacking modern safety improvements) it may not even be safe to charge them if below 2.0V.
While there have been safety improvements over the years to reduce such risks (e.g. browsing patents reveals chemistry improvements to suppress copper dissolution, and ceramic separators to suppress or localize internal shorts) there is generally no way for consumers to know which improvements apply to particular cell models, since such information is not typically provided to the general public.
Further info can be found by searching on "
near zero volt storage". Due to recent Li-ion transportation restrictions there has been a flurry of research on possible ways to improve Li-ion cells so that they can be safely stored at near zero voltage (near
0V) because this greatly increases safety, e.g. it increases thermal runaway threshold temperature, and greatly decreases amount of gas production, and eliminates all toxic gases, etc. Many of these recent papers link to the (scarce) earlier literature on overdischarge topics, and give brief overviews.
For example, see Kyle R. Crompton's 2017 RIT Thesis
Enhancing Near Zero Volt Storage Tolerance of Lithium-ion Batteries. Below is an excerpt from pp. 19-20.In the following section he mentions some prior research on related matters, which might be a good place to begin any further investigation on this topic.
KyleR.Crompton said:
It is important to note here that determined values of the onset potential for copper dissolution can vary since the choice of an oxidative current density threshold is arbitrary and non-faradaic process can contribute to the oxidative current. Additionally, the exact value of the onset of copper dissolution can be affected by factors such as ambient conditions and electrolyte composition. In the present work, 3.1 V vs. Li/Li+ will be assigned for interpretation purposes as below this value, no oxidative current was observed in the linear sweep voltammogram in Figure 9d, and therefore, no copper dissolution is expected to be occurring.
The adverse effects from copper ions being present in the electrolyte will lead to side reactions with the electrolyte, competitive reduction processes with lithium ions, and copper dendrite formation which can lead to internal shorting. Each of these effects can cause significant damage to the cell and reduce its recharge capacity and performance.[8591]. Thus, for cells to be tolerant to near zero volt storage, cell design must be modified or different materials used to avoid the copper dissolution degradation mechanism.(emphasis in original)
Below are excerpts of Samsung datasheets showing the
1.0V lower prechargelimit, from
Dec. 2017and
July 2015.
