floydR said:Wouldn't it also matter how the batteries are connected to the load?
one battery has the positive of the combined 24v battery and the other battery has the negative?
Later floyd
Eddieb said:[...] In theory even if it did have 80 amps of charging it should split 40 to each bank? (assuming similar health and capacity).
Eddieb said:Redpacket, below is the link to a wider shot of the bus bars and leads. Are you saying move the red lead to the other end of the bus bar?
Bus bars 2
enzo86 said:I also had a similar question to the OP's Post, So to add to the OP's question: A 7S80P pack using 3000 mAh cells, Assuming a 0.5C (1.5 amp) discharge rate
That would be 120 amps at 29.4(ish) volts = 3528 Max Watts
240Ah * 29.4 = 7.056 Kwh (not taking into account any losses.
Are these safe numbers, 1.5 amps seems like a lot from each cell, i have read where some are not expecting over 200-500ma draw per cell, but I assume this is why you build larger sized "P" packs.
