Parallel CCCV charger
Hey,
for my project i want to use my battery only to store the energy from my solar panels i do not use that moment. Especially at noon. So i measure my solar input and my total input from the grid. To have something like a controlled charging that switches to higher charge powers on need i want to use parallel cccv chargers that can be switched by esp8266 powered relays as needed (like 100w +100w + 100w+100w) to charge the same battery pack.
I want to switch it on the input side because i heared it can be dangerous to connect input before the battery pack.
Is there anything i need to know or any concerns about this method?
Maybe try & do the switching with MOSFETs, much better with DC than relays :-)
You might be able to find CCCV devices with an logic level "enable" pin?
Can you make a drawing on your intention to hook it Up?
Crimp Daddy likes this post
Not enough info given so I can only suggest other possible easier solutions like using a cc/cv chargers that are programmable through a serial connection like this https://www.ebay.com/itm/Programmable-DC...3581609257
Or if you use a mppsolar PIP inverter I believe it's possible to change the charging amps via the serial connection.
I'd rather do that trying to set relays to turn on and off a whole bunch of small chargers.
(08-16-2020, 04:01 PM)not2bme Wrote: Not enough info given so I can only suggest other possible easier solutions like using a cc/cv chargers that are programmable through a serial connection like this https://www.ebay.com/itm/Programmable-DC...3581609257
I never saw that unit before... thanks for the link.  Do you know if they make a DC boost version of that?
Seems like it would be ideal for battery charging... I need something like this for 24v lion charging from a cars 12v system.
From the looks of it it's a step-down only. Eevblog did a review of it recently. https://www.youtube.com/watch?v=GUxszz_lo14
But for the step-up charger, the only one I know of may be just to use a MPT-7210a instead? Never used the unit myself so not sure if you can limit the current?
The MPT7210 have a current setting built in.
(08-21-2020, 10:27 AM)not2bme Wrote: From the looks of it it's a step-down only. Eevblog did a review of it recently. https://www.youtube.com/watch?v=GUxszz_lo14
Yes, I do have a MPT-7210a and it works just fine for that application... current limiting DC boost.  I was just curious if there were others.
Thanks for the youtube video link too.
