  • 1 Vote(s) - 5 Average
Pack Builder (Repackr)
(01-02-2019, 05:26 PM)benhamel Wrote: The paste in spreadsheet is nice but can this be saved in my account? Can I / you give packs name / code to easily associate bin to pack while sorting batteries.
Thanks for this tool
I have plans for the repackr. Plans that will address this along with adding several new features. It's still a few months away though.
Korishan, hbpowerwall, Dietmar Rheeder-Kleist And 1 others like this post
I record my cells into a spread sheet, from the time I open the original battery pack, recording the initial voltage, first charge voltage, test voltage after 3-4 week, capacity charge, last charge voltage,  each cell has it own ID so I can reference it back to my spreadsheet for information about that cell if need be,
what I would like is that when the cells are entered into repacakr,  that I can enter the ID and Capacity,
and it spits out the ID in the groupings, so I can then easily find the cell I need for each pack / bank.
can this be done ?  or have I missed somewhere it's already doing this,
thank you for your time,
Nigel
#13
Yes, but repackr isn't programmed that way. Take a look at Brett Watty's build: https://secondlifestorage.com/t-Arduino-...ery-Tester
He has a system that id's each cell with barcodes and pull the data from the cell database.
#14
(06-27-2019, 11:07 AM)Korishan Wrote: Yes, but repackr isn't programmed that way. Take a look at Brett Watty's build: https://secondlifestorage.com/t-Arduino-...ery-Tester
In the end I wrote some code to do what I needed ( using the repackr output )
i'll put it here in case anyone is interested, it's written in AutoIT,  it's rough,  but works for my needs,,
example of the data I used,
-- MyData --   ( has battery ID and Capacity )
B1,5385
B2,5293
B3,4500
B4,4756
B5,4499
B6,4736
B7,4148
B8,5299
B9,4216
B10,4242
B11,4203
B12,4080
B13,4112
B14,4432
-- Data entered into rePackr ---
5385
5293
4500
4756
4499
4736
4148
5299
4216
4242
4203
4080
4112
4432
--- output from rePackr --  put this into a spreadsheet and saved as a .csv file
4756    5293    4500    4432    4736    5299    5385
4216    4112    4499    4242    4203    4148    4080
--- Run it through my code, and the output ---
B4,B2,B3,B10,B6,B7,B1
B9,B13,B5,B14,B11,B8,B12
--- and the code I wrote  ---
Code:
#include <MsgBoxConstants.au3>
#include <Array.au3>
#include <File.au3>
$BatteryPreFix = InputBox("ID Prefix","If you use a letter Prefix in your battery numbering, enter it here","B")
$sMessage = "Select your .csv file"
$BaseFile = _OpenMyFile($sMessage)
Dim $BaseFileArray
$sMessage = "Select your rePackr .csv file"
$RePackrFile = _OpenMyFile($sMessage)
Dim $rePackerArray
_FileReadToArray ($RePackrFile,$rePackerArray,0,",")
_FileReadToArray ($BaseFile,$BaseFileArray,0,",")
$Series = ubound($rePackerArray,2)
$Parallel = ubound($rePackerArray,1)
$PackSize = $Series * $Parallel
$BaseSize = ubound($BaseFileArray)
if $BaseSize < $PackSize Then
    MsgBox(0,"","rePackr and Base '.csv' files are not the same size" & @crlf & "rePackr file is " & $PackSize  & ", baseArray is " & $BaseSize)
    Exit
EndIf
ConsoleWrite("$Series " & $Series & ",   $Parallel " & $Parallel & @CRLF)
TrayTip("Building Pack Data","S" & $Series & ",   P" & $Parallel, 10)
_ArraySort($BaseFileArray,1,default ,default ,1)
For $loopSerial = 0 to $Series -1
    for $loopParallel = 0 to $Parallel-1
        For $loopBase = 0 to $BaseSize -1
            if $rePackerArray[$loopParallel][$loopSerial] = $BaseFileArray [$loopBase][1] then
                $rePackerArray[$loopParallel][$loopSerial] =  Number(StringReplace($BaseFileArray [$loopBase][0],$BatteryPreFix,""))
                $BaseFileArray [$loopBase][1] = ""
                ExitLoop
            EndIf
        Next
    Next
Next
    Dim $tempHoldArray [$Parallel]
        $tempHoldArray[$loopParallel] = Number($rePackerArray [$loopParallel][$loopSerial])
    Next
    _ArraySort($tempHoldArray)
        $rePackerArray [$loopParallel][$loopSerial] = $BatteryPreFix & $tempHoldArray[$loopParallel]
    Next
;    _ArrayDisplay($rePackerArray)
Next
$sFilePath = "MyPackFile.csv"
_FileWriteFromArray($sFilePath, $rePackerArray, 0, Default , ",")
MsgBox(0,"","Exported Data to file:" & @crlf & @ScriptDir & "\" & $sFilePath)
ShellExecute(@ScriptDir)
Exit
Func _OpenMyFile($sMessage)
    Local $sFileOpenDialog = FileOpenDialog($sMessage, @ScriptDir & "\", "csv (*.csv)", BitOR($FD_FILEMUSTEXIST, $FD_MULTISELECT))
    If @error Then
        MsgBox($MB_SYSTEMMODAL, "", "No file(s) were selected.")
        Exit
    Else
        $sFileOpenDialog = StringReplace($sFileOpenDialog, "|", @CRLF)
        return $sFileOpenDialog
    EndIf
EndFunc
#15
(06-27-2019, 02:07 AM)noddle Wrote: I record my cells into a spread sheet, from the time I open the original battery pack, recording the initial voltage, first charge voltage, test voltage after 3-4 week, capacity charge, last charge voltage,  each cell has it own ID so I can reference it back to my spreadsheet for information about that cell if need be,
Nigel
I built an excel based repackr that does this.
Here's the thread: https://secondlifestorage.com/t-Excel-based-RePackr
Find the file on My google Drive: https://drive.google.com/drive/folders/1...49m5V34Ug6
Mobilis in Mobili
Cell count as of 10/10/2019
234 Cells >2000mAh, >80% Rem. Cap., 14 day resting voltage >4.12V
191 Cells of Everything Else
68 In progress
Aiming for 8 cells tested a day
More info on my Google Drive
