Battery capacity ?
(09-03-2020, 08:47 PM)daromer Wrote: Diggsut when doing 4 cells its only 0.5A during discharge. The lack of function i talk about is the stresstest. The Lii have lower current during a cycle test and therefore i call it lack of function Smile
You can ignore the IR test on those testers. They can vary 100% or more easily and are pretty of from the start. Get a 4-wire tester instead. Smile
Hmmm..... Default is .5A but you can choose 1 amp through the menu for discharge and cycling.
Agreed - A four wire tester should be used for IR. I never put much faith in the absolute IR value other than relative to other cells being tested.
1a then its max 2 cells. As soon as you put in 4 cells the discharge goes down to 0.5. its also mentioned in the specifications.
