My first pack, my first power wall.
Spot welded the positive side with fuses from BatteryHookup. The other side, these Double nickel strips from China. Now for the crossing direction, do I need to weld that strip on for every row, or as Ive done it so far - for each 5 rows?
The AC load will be around 7kwh - powerwall will be 14s188P when all 14 cells are done.
See image -
https://ibb.co/rFbMCCw
See image -
