Harvesting Issue
Personally - I wouldn't fool with it / risk it.   Almost new cells are very cheap these days - not as if they are $10 each Smile
DiggsUt likes this post
Hello guys, Im new and i luckily can't add this from my experience yet. I always seemed to twist them with pliers. It sometimes damaged the wrap but from a few 100 harvested cells i've never had a leaking cell happen.
#13
(09-23-2020, 01:38 PM)quadrofource Wrote: Hello guys, Im new and i can add this from my experience too. I always seemed to twist them with pliers. It sometimes damaged the wrap but from a few 100 harvested cells i've never had a leaking cell happen.
If you pull hard/sharp-enough it can happen.  The 'cans' of 18650 cells are not 'thick metal' as they seem and if you pull out a really strong spot weld (instead of clipping the nickle off) you can get a hole Smile
#14
im lucky it never happened to me yet Big Grin
#15
I just have to lay off the Wheaties then.
I have started to try twisting them off. It seems to be more of a problem with dewalt battery packs with thick metal tabs.. All the ones that have had holes are from those packs..
Wish there was an easier way to disassemble them with out causing lots of sparks. Gets me every time at least once.
Metal drops below the protective ring then zap sparks.. Makes me jump every time..  Smile
#16
dropping bits of tabbing through the vents can cause a welded short you cannot remove.
if its a good cell with enough charge this can mean an "oh shit" event.
when i am cleaning cells i use magnetized flush cutters.
the crumbs stick to them and i can clear them off.
never had any short a cell.
