BMS for nissan leaf modules
Hi,
Can some one recommend me affordable BMS for nissan leaf modules.
regards.
Very vague question... What type of load and what is your price point. How much balancing current do you require? If your cells are well balanced then you can get away without a high balance current and move into a more affordable monitoring only solution like a Bluetooth board.
Define affordable?
What are your must and nice to have demands?
Hi,
i came across this.. https://www.batrium.com/collections/cell...leafmon-7x
its 7s4p ...
cell 7.6V 60Ah.
sorry for my bad english.
You can use the WM4 with the leaf mons or the WM5 (I have WM5 for my leaf wall) the leaf mons and WM4 will balance a pack faster thou.
(09-12-2020, 09:59 PM)slimf Wrote: You can use the WM4 with the leaf mons or the WM5 (I have WM5 for my leaf wall) the leaf mons and WM4 will balance a pack faster thou.
Any other BMS that can work... other than wm4/wm5 ?
Regards
REC BMS
(09-13-2020, 12:05 PM)slimf Wrote: REC BMS
ohhh
