slimf said:You can use the WM4 with the leaf mons or the WM5 (I have WM5 for my leaf wall) the leaf mons and WM4 will balance a pack faster thou.
ohhhslimf said:REC BMS
I'm using a cheap generic 60A BMS, but then using a dc/dc buck converter with a Tyco contactor. That handles the voltage constraints for each cell and whole battery. I also have it fused with a type-T fuse (which you should anyways even if you have a BMS that can use a shunt to monitor current and shutdown).s4sajii said:Hi,
Can some one recommend me affordable BMS for nissan leaf modules.
regards.
