identifying some cells
6A is good enough.
Can you post a few pics with the others ?
Maybe we can find out more.
To mix them, it's a little complicated (assuming the others are low current).
You will have to make identical packs of parallels then put them in series to get what you want.
From here, you have multiple situations:
- when you don't exceed the current drain per low current cell - works continuously
- when you exceed it a little (and 6A ones will take the additional current) - here you may use the battery with pauses for re-balance (energy compensation transfer from 6A to the others) - works with breaks
- when you exceed it by a lot and the low current cells will overheat - not recommended - works only for quick bursts
