I have 10.5kW of solarpanels on the roof, and a 15kW inverter to supply the grid.
Now I want to start with a DIY powerwall, but I want to do it right. Do I replace the 15kW inverter with a hybrid inverter?
Or do I just do the batteries separately, with a charger, BMS and a second grid inverter?
I wouldn't mind creating the rules/switching/controlby myself (when should the batteries charge, how much amps should they use to charge, same for supplying the grid), but I'm thinking this would go wayyyyyy easier with an integrated hybrid inverter, as not all inverters/chargers can be easily monitored/controlled through a communication bus I believe.
I am not off-grid, but I pay more for electricity I take off the grid at night than I receive for the power I supply to the grid, and that difference will continue to rise over the next 10 years or so.
