GTIL Autosense with Limiter question
Question
Hi All Experts,
Finally I got my Sun GTIL grid tie inverter with limiter.
Im testing it with out any isolar panel and battery feeding it and.....
I did the serial dual clamp connection and seems to be reading it nicely.
But.... when I have everything disconnected.... I got a reading of 5W from the grid.... is this a default value to avoid to backfeed?
I think I read about this reading value from the grid of 5W, aynone with experience with the Sun GTIL grid tie inverter with limiter that can let me know if Im wrong?
Thanks is advance,
507PowerWall
Based in Panama
Off-Grid
PV = 3 x 200W
Bat = GEL 250Ah
Feeding Fans / CCTV / Modem-Router / Android Boxes
Going on-grid
** 345 ** batteries harvested / getting GTILv2 2Kw auto sense 45-20V 240V
Lots of items coming from china - usa
...Updating as progress flow...
The inverter always allows the grid to supply a small amount of power. When you say “everything disconnected” what do you mean. The inverter uses ac power to operate so the inverter would supply the power it itself is using and still allow the grid to supply a small amount.
https://www.facebook.com/groups/1455824754596738/
507PowerWall likes this post
(10-07-2020, 06:46 PM)507PowerWall Wrote: Hi All Experts,
Thanks is advance,
507PowerWall
Thanks for your quick response, on my test, I have my kilowat metter down .... so I can't validate that reading of grid consumption is accurate, but the good things is that is reading a bit less that actual W consumption, so is more difficult to backfeed
Thx again
