MrAlfabet said:
I'm not going off-grid so I only want to back feed into an online grid, this is for an energy storage system. Storing cheap energy during the low hours (with a separate charger), using it grid-tied with an inverterduring the peak hours.
There is a difference between grid-tied and grid-tied, unfortunately. This can be very confusing.
First off, you say you want to feed back into the grid for energy storage. I'm not sure what you mean here. Are you meaning you are using the utility grid as a storage device and you send power back to the power company and get a reduction on your power bill. Then use that power during off-peak hours to get a cheaper rate?
Or are you meaning you will be merging battery storage with your in-house electric so that you use primarily battery and then have the utility grid to supplement anything above what the battery can handle surge or time wise?
If you are doing the first option, then options are limited. And you need to verify with your power company if they will accept that device. They can be
very picky about what devices they allow on their network
If you are doing the second option, there is a lot more leeway here as there are plenty of inverters that will do this merger.
The inverter you posted from Aliexpress doesn't feed back into the grid. It just limits how much comes from the grid to be merged with battery/solar input. This is why I'm asking these questions because you said you want to back-feed, but at the same time you aren't. So this confusion needs to be cleared up before you go and purchase something you don't need.
