  • 4 Vote(s) - 5 Average
Esperyd´s Raspberry PI project
I have 2 5048MG in parallel so I have 2 services running in two different tables (pip_query_general_status and query_general_status).
Do you know how can I sum the production of my PV from the both tables in a SingleStat ?
I'm working on a node-red flow to capture data from a pzem-016 instead of the SDM modules. The PZEM can be found for around $10 on eBay and also use ModBus over RS485
https://www.amazon.com/Frequency-Communication-Voltmeter-Multimeter-interface/dp/B07S6SFKTK/ref=sr_1_1?keywords=pzem-016&qid=1568119518&s=gateway&sr=8-1
I
 have figured out the addresses and created a flow to capture the relevant data.
I'll probably end up integrating this into your daromers diypowerflow project, is anyone else working with PZEMs?
(09-04-2019, 08:29 AM)Lagachette Wrote: I have 2 5048MG in parallel so I have 2 services running in two different tables (pip_query_general_status and query_general_status).
I managed to did it with node red.
Other question, is it possible to know the current source of my inverters, if they taking energy from grid or solar+batteries ?
LPG: I have them here to but i havent used them in my real system. I wanted more accurate readings and something my electrician would approve to use.
The SDM120 is sligthly more expensive but on other hand i like the higher quality Smile
When you have your flow done feel free to post a paste.bin link to the exported flow. I bet someone else would love to use it.
(09-11-2019, 09:13 PM)daromer Wrote: LPG: I have them here to but i havent used them in my real system. I wanted more accurate readings and something my electrician would approve to use.
That's my plan, I'm currently working on the power flow node project by fernandu (easier to modify his than your fork) I got the MQTT to work but for some reason it's not registering packets going to the grid.
I also saw the SDM120, problem is that they're rated at 40A, in the US when using split phase I'd have to use 2 of them (one for each L) and I need 125A so I have to use a non-invasive (CT based) meter.
My fork is based on different layout yes Smile
I should refork His to get websockets but havent bothered yet.
Yeah max current in sdm is low in your standards. Sweden is 16-25a at most per phase Smile
daromer I want to start by saying thank you for the hard work, I'm not so good with software and I would like to use your ISO to get a nice Grafana interface for the DiyBMS V4.
Somebody already used daromer ISO and DiyBMS and can share an image or some tips on what I need to configure to make it work?
For the moment I have a 7s DiyBMS working fine an a raspberry pi 3+ on the way.
You really dont need my ISO for that. You basically only need a Raspberry with Grafana + influxdb and some way to get the data stored Smile
Perhaps someone got it.
I should get me a DIY BMS some day to incorporate hmm
glide likes this post
(09-21-2019, 06:17 PM)daromer Wrote: You really dont need my ISO for that. You basically only need a Raspberry with Grafana + influxdb and some way to get the data stored Smile
Any chance you can share the JSON for your Grafana dashboard. I have been banging my head around trying to get a good influx query to calculate kWh used in a given period of time but I keep coming up with odd numbers, maybe looking at yours would help.
You have the code eatlier in this threads.
Users browsing this thread: 5 Guest(s)
