7s config balancing question
(07-16-2019, 02:58 PM)MattBarnesJCKS Wrote:
(07-16-2019, 11:56 AM)daromer Wrote: You end up with that because you dont have a BMS that do balancing as you need it to do.
Thats also the reason why you need a BMS with proper balancing functionality Smile
Correct.  That's my issue.  How to keep it bottom balanced...
The balance at the end of a discharge cycle will depend on how closely matched your cells capacity are, combined with the BMSs ability to actively balance (few do) - top balanced packs are the norm here.
Why bottom? Its not in the bortom you Will see issues. Overcharge cells are 100* more dangerous than undrcharged. I would highldy recommend top balanced battery bank or use active balancing.
Systems that do bottom are rare
Korishan likes this post
#13
I concur with Daromer. Top Balance with cutoff at at lease 3.5V/cell as to not let a bad cell get too low
#14
Cut off should be 3 or even 2.8... on bms Side that is. In this case the Ups decides total voltage cut out
32 User(s) read this thread:
daromer (07-16-2019, 07:03 PM), whoinow (08-15-2019, 01:37 PM), Bayyn (07-17-2019, 10:07 AM), Solardad (07-16-2019, 01:30 AM), stevelectric (07-16-2019, 11:54 AM), eric.peton@laposte.net (08-05-2019, 09:21 PM), ajw22 (07-16-2019, 04:02 PM), kevinjaye (07-16-2019, 02:21 AM), OffGridInTheCity (07-17-2019, 08:10 PM), Tiger_one (07-15-2019, 06:46 PM), juanjo57 (08-13-2019, 08:55 AM), Janusz (08-15-2019, 10:46 PM), heiko (07-22-2019, 03:48 PM), 7h0r (08-11-2019, 05:42 AM), Mikal (07-23-2019, 01:43 PM), b0re (07-30-2019, 08:00 PM), runsnbunsn (07-21-2019, 07:21 PM), Sean (07-16-2019, 07:16 PM), Korishan (07-16-2019, 10:43 PM), jdeadman (07-16-2019, 07:06 PM), wim (07-17-2019, 05:56 AM), wimpie007 (07-30-2019, 05:58 AM), Geek (07-16-2019, 01:24 AM), djuro (07-17-2019, 06:31 PM), sturgeo (08-11-2019, 09:21 AM), Lindsaymac1 (07-16-2019, 08:13 AM), Issac (07-17-2019, 12:19 PM), Crimp Daddy (07-15-2019, 10:47 PM), Bubba (07-16-2019, 12:51 AM), grumble (08-07-2019, 02:07 PM), MattBarnesJCKS (07-25-2019, 10:52 AM), 3xtr3m3 (08-10-2019, 09:56 AM)
