Doing it right has many interpretations and variations.
But one thing always stands out we all want to do it as fast as possible.
The problem is that there are many factors in successfully harvesting used 18650 cells.
Everyone has their "preferred method" of doing it right.
Is there a right way, a wrong way, or a better way?
I do believe there is.
The first step is to learn about cell chemistry. For the sake of simplifying it I will refer to two different chemistries most common to those of us that harvest cells (specifically 18650s)from laptop and toolpacks. INR and ICR highdrain and lowdrain respectively.
These 2 chemistries have radically different criteria by which to charge and discharge them.
Example:
INR18650-15M standard charge750mA and standard discharge 1500mA this cell is meant to last an hour but deliver peak power for that hour.
ICR18650-26F standard charge 1300mA and a standard discharge of 520mA this cell was meant to last5 hours at a standard drain and would more than likely deliver 10 hours at 260mA drain.
Now these 2 examples are at the opposite sidesof the spectrum for each and most cells of either type are somewhere in the middle but it is to prove a point.
Certainly there are maximum charging and discharge parameters given for each cell such as there is a maximum RPM given for each engine. Does that mean we will keep them at max RPM all the time? No. Just as with an engine that has some miles on it we don't floor it at every stop sign just every now and then. Most of the time we are using a 10th of the engines power.
There are reasons the manufacturer of these cells put out specification sheets for each and everyone of their models and give you the charging mA numbers and discharging mA numbers by which to test the cells at.
All 18650 cells are not alike as in generically charging them all at 1000mA and discharging them at 1000mA. There is a reason most charger/testers have several different mA settings.
Lets take aCGR18650CE Panasonic(found in medical packs and laptops) for example. The Factory recommended "Standard charge rate" is 430mA at CV/CC for 8 hrs or a quick charge at 1500mA CV/CC with a 110mA cutoff at the top of the charge. The standard discharge is 430mA and the maximum continuous discharge rate is 2500mA with a 45C shutdown.
How do our OPUS, Foxnovo, LiitoKala, Zanflair etc. fit into this parameter? they don't.
So what do they provide?
They provide an acceptable average charging rate and discharging rate for a majority of the 18650 cells we use.
One thing of noteis a lower mA charge is never going to hurt your cell (it just takes longer to charge) but a higher than recommended mA charge will.
My findingwhether right wrong or indifferent is that I charge ALL my <3V (that includes 0.5Vcells, all in separate voltage batches of course, in parallel)at 50mA per cell till they hit at least 3.8V and most of the time I will let them charge at 50mA till 4.1V. You cannot hurt a cell with low mA and slow charging.
Another note is that all the cells I charge have to initially pass an IR check. This is done with the manufactures recommended method with a m? AC1 kHz4 wire kelvin resistance tester. This is manufacturer and cellspecific and varies from manufacturer to manufacturer and cell part number to cell part number.
Does it take more time sure but the results are very good and these cells are not a flash in the pan as 98% will maintain their V after 30 days and I have spot tested many of the low V recovered cellson my SKYRC at manufactures standard charge and discharge rates and most of them have stayed the same mAh as first tested and some of them actually improve very slightly on each cycle.
Does it take time yes it does but a wise old man once told me"There never enough time to do it right the first time, but always enough time to do it over".
So my suggestion is do your research, follow good guidelines, a lot of people here have great input and are very knowledgeable about this subject and most of alltake your time and do it right.This is at least a commitment for anywhere from 6 month to a year depending on the size or your packs. For me it will be ongoing but it will slow down after my 14s200p is built.
Best of luck and do it right.
