Crimp Daddy
- Feb 21, 2018
- 973
I have been processing some laptop packs and get some cells that get extremely hot during charging Not Sanyo cells, but ones like this
https://secondlifestorage.com/t-Panasonic-CGR18650E-Cell-Specifications
and
https://secondlifestorage.com/t-Panasonic-CGR18650D-Cell-Specifications
I decided not to use the Lii-500 chargers to charge them for testing because if I just limit the charge to 4.0 or 4.1, I can control the heat much better. They tent to get too hot to handle while its trying to reach 4.2v, and often times take forever for charge to terminate. They just sit there cooking. I will charge using my iCharger, and discharge test only with the LitoKala. Also, does the heat subside after multiples cycles, has anyone tested this?
If these cells still test with some capacity what would use you them for? I was thinking of making a portable battery pack for some camp lights... non critical things or smaller projects where the loads are extremely low current for both charge and discharge.
and
