viralprankster
- Jan 25, 2018
- 30
II have installed Bluetooth bms of 7s , the total voltage is only 6volts when am measuring at -c . I tried it so many times . First when I spoke about this technical problem with the store on AliExpress he or she said you have removed the temp sensore wires . I thought if i connect it i will get the perfect voltage and when I tried with that the total voltage is same 6volts . I have installed as per the diagram and also by watching vdios on youtube. I did find a something am not sure of . The balance wire has a gap among them... in place of 5th pin .... when I spoke to shop person on AliExpress this is what he said
What could be the problem???
By looking at the pins even the balance wire is ok whr could the problem?? Any guess
