  • 2 Vote(s) - 5 Average
Cell Database Submissions and Updates
#61
Found a cell not in the database:
SONY-FUKUSHIMA 17670 G6
I'll try to get better pictures of them.
Moreover, the Highstar ISR18650-1300 already in the database has changed the style to a different one like this:
No. cells
Indexed: 53
Processed ok, not yet indexed: ~700
Broken down, untested: ~1200
Not yet broken down: ~40 kg
#62
Brand:  Exell Battery
Model:  EB-LFP-14500-600
Capacity:  600 mAh
Voltage:  3.2V Nominal
Cell Size:  14500
Diameter (mm):  13.9
Height (mm):  50.2
http://www.exellbattery.com/products/lithium-batteries/
#63
Brand: Panasonic
Package: 26650
Model:  CGR26650A
Capacity: 2650 mAh
Voltage: 3.6 V nominal
Charging: 4.2V, max. 2500 mA, 250 mA cut-off
.pdf   CGR26650A.pdf (Size: 63.78 KB / Downloads: 4)
No. cells
Indexed: 53
#64
LG18650M26 is the LG medium power cell with capacity of 2600mAh and 10A continue discharge current, a very popular economic cell used in power tools, energy storage, home appliance, and medical device
3.6V
10.0A
#65
Brand:  Soshine
Model:  14500-3.2-700
Capacity According To Manufacture:  700 mAh
Cell Size:  14500
Information From Manufactures Website
Type:LiFePO4
Nominal voltage: 3.2 V
Nominal capacity: 700 mAh
Core cell weight: 27 grams
Maximum Continuous charge: 1C
Maximum Continuous Discharge: 1.5C
Typical fast charge current: 1C to 3.8V CCCV
Fast charge time: 30 minutes
Cycle life at 0.5C discharge, 100% DOD: over 1,000 cycles
http://www.soshine.com.cn/a33.aspx
Attached Files Thumbnail(s)
#66
Samsung ICR18650-24B
Best I can find for specs.
https://merkandi.us/archive/battery-li-i...mah/256007
Last count as of 3/23/2019
Total Number of Cells           3743
Cells  >80% of Capacity        2445
Cells <80% of Capacity         1265
Cells ≥2200mAh & ≥ 80%     1709
Google Drive for info https://drive.google.com/drive/folders/1...sp=sharing
Not your average Wolf
            Cool
#67
CNR18650
allready in the database but found some specs
  • Rated capacity: 2200mAh (0.5°C)
  • Minimal capacity: 2100mAh (0.5°C)
  • Rated voltage: 3.7V
  • Charge voltage: 4.2V
  • Charge mode: CC/CV
  • Charge time standard charge method: 3.0 hours (for ref.)
  • Quick charge method: 1.5 hours (for ref.)
  • Maximum continuous discharge current: 2A
  • Discharge cut-off voltage: 3.0V
  • Working temperature charge: 0 to 55°C
  • Discharge: -20 to 75°C
  • Storage temperature: -20 to 45°C
  • Storage humidity: 85RH
  • Battery weight: 44g (approximately)
https://www.globalsources.com/si/AS/Qinh...062736.htm
Nominal voltage. 3.7v.
Nominal capacity. 2200mah.
Resistance. <=60.
Max continue discharge current. 3a.
End of charge voltage. 4.2v.
End of discharge voltage. 2.75v.
Cycle life. >=500.
Weight. 42g.
https://www.globalsources.com/si/AS/Qinh...149756.htm
100 User(s) read this thread:
hbpowerwall, daromer, Sean, mike, station240, RobPethybridge, NERDVille, Majorphill, riveracc1, ruby2, Korishan, PAF, brettwatty, Batrium, Wattsup, skyfridge, CrankyCoder, Droid126, jdeadman, Zagy, 2146, wim, wimpie007, frnandu, typ49, HandyAndy, Allan Gilbert, Kaspars Krumins, Tychipowerwall, rebelrider.mike, watts-on, jesusangel, João Luis Martins, alexcj, Hanssing, IronSky, bfleury, OmgImAlexis, ridiculously_necessary, Mark Lex, Stefaan De Ridder, Mario, Chiptosser, Ryan Dwyer, BlueSwordM, tremors, Piotr Dziel, idiomatically, Terry, Eric Koshinsky, KaminoReal, Shade, al4sound, Mazlem, kiwi, Timothy_Hennessy, ivnz, Geek, Rad, Longbush Powerwall, SWEwall, jamesk9, mr_hypno, floydR, Jimlun, mickduc, Jonas Goiris, Russell Smith, sunseeker, hookemdevils22, Learjet, NaoDarkness, grgdgreek, g1naveen, DarkRaven, Gerard Achternaam, frenchclem17, Grumplestiltskin, hOOPSNAKE, Joey T-Bone Smith, DCkiwi, emerca, ChrisD5710, Chris Solomon, Tostaki, Nauti, Hillbilly, howiegrapek, dpear, cristof, Oderus420, Oz18650, accoelho, r34king, aidynphoenix, rev0, Bryn, how about that, 4point0, xXxOlivierxXx
Users browsing this thread: 4 Guest(s)
