Hey guys, I'm in to the testing phase of a bunch of cells that I have harvested from laptop batteries.
Out of roughly 1200 cells, Ihave sorted a few hundred to the top of the pile that look like good candidates for my current project.
I'm about a week in to charging them allup to about 95% or sowith a couple of hobby chargers, weeding out the warm cells. etc. The charged pile is starting to build.
I've searched all over the confuser, far and widefora cost effectivemethod to conduct testing with a resistive load type discharger. I'd like to to 10 or more at a time, as it would niceto have my batterybuilt this decade.
This is what my search has come up with so far:
ZB2L3 v2.1 Module
Pros: Seems pretty accurate and reliable from looking at reviews and youtube tests. Cheap! around $6aud per module
Cons:Out of stock on banggood, long postage times from other sources (China). No casing.
Opus BT-C3100(or similar)
Pros: Recharges cells, cutting out the need to go back to the hobby chargers. Compact. Available.
Cons: The conclusion of that test in the link states that the peak currents can be a bit high for charge and discharge, but acceptable for what Iam doing. More expensive at around $60 a piece. I would want at 2 at least.
"Mobile power" tester
Arduino? Though all projectsIhave seen only do one at a time.
What do you guys use for bulk testing?
Thoughts on a good/cheapset up?
ZB2L3 v2.1 Module
