Hi - noticed a few members that have this inverter (either easun or mpp version):
https://www.ebay.com/itm/2kva-1600w...ery-charger-/132841577019?hash=item1eedf99a3b
Wondering how they are working so far for folks that have them up and running? Any issues?
I am thinking of getting one to add to my current setup that uses two SUN-1000gtli, one for each leg. (In US so split phase panel).
https://secondlifestorage.com/t-External-limiting-an-GTIL2-SUN-1000G2-with-raspberry?page=10
My thought was to move my current SUN inverters to a single 110v leg of the panel and get the 1648 for the other leg.
I am a little fuzzy of the AC hookup side and how the 1648 handles loads. Maybe someone can answer the following.
1. How does the AC input work, dedicated breaker for the inverter and another dedicated for the output? I was thinking 2 15amp breakers on the same leg. What are folks panel setups like? I found the manual lacking that detail.
2. What happens if the panel load exceeds inverter capacity? Will is just switch 100% to utility or would it supplement, example a 2000w load so 1600w from inverter and 400w from utility?
3. 240v loads. I have a few 240 circuits that I am stuck with. Has anyone seen any impact to their own 240appliances? Wondering if the 1648 does a full switch over to utility if the cutover is quick enough that the appliance is not impacted, washer, dryer, stoves, etc..
Thanks!
Thanks!
