completelycharged
Active member
- Mar 7, 2018
- 1,083
Having looked at a lot of BMS systems I thought I would have a go at createing one with a difference.
My setup is going to be 33s8p modules (18kWh at 72V) and each of the 8p cells will have a separate balancing unit.
My plan is to use ESP8285 (2) to monitor and balance individual parallel sets of cells and have them powered from the cells they are monitoring and communicate via wireless so there is no wiring from or between cells. Also the whole thing then becomes completely scalable because you just add one ESP8285 for each parallel set of cells that you have.
I have part of the code written and tested so far and the majority of the electronics sorted in my mind (some parts on orde) with the view that each BMS point will cost less than 5 per point and provide 1 second resulution data to allow current spikes to be profiled and analysed for battery condition and failure detection.
In my case I aim to have 33 units, one attached and mounted on each parallel set of cells, talking wireless back to my computer with no wires trailing around.
Are there any comparable cheap/reasonable BMS systems that are wireless and cell based with good lessons to learn from ?
