Ebike help
Hi Guys,
So I've been harvesting cells for a few months now. I've got about 120 good cells (most have 2000+ aH) and my goal is to make a ebike. I got some question that hopefully you guys can help me out with. I'm trying to make a battery that can power my ebike so it can take me to work and back, and thats roughly 30 miles. I'm a big guy. I weigh 230 pounds (104.3 kg) and im 6 feet 3 inches (190.5 cm) tall.
How many wH should i aim for?
I'm goign to buy a conversion kit that has a 48V1000W brushless gearless hub motor. I believe i can make a 4.94 kWh battery (103aH * 48v) with 52 cell (103aH/2000mAh **roughly). Is my thinking wrong on this? is this enough?
Guidence appriciated.
Thanks.
EDIT:
Turns out i did my math wrong... I am making a 13s4p battery. So its 4 * 2000mAh = 8Ah. Then it would be 48.1v * 8Ah = 388.8wh. Is this right?
Are you getting a bafang motor set up? I have that motor and run a 13.2ah battery and get roughly 70km out of a charge. I'm 80kg and 167cm, I am also a Fit person and still ride it as much like a normal bike as possible. If I don't put much effort into pedalling and use it more like a motor bike I can get around the 20 to 30km from a charge. This is me riding at an average of 30km per hour.
Hey mate,
I've made 2 ebikes and learned a lot.  Both have a 48V 1,000W hub motor on a 26in rear wheel.
1) 1st attempt used a 13S8P battery made from recycled laptop cells (av 1.95Ahr so ~ 750Whrs)  1,000W hub motors pull about 20+ Amps so using laptop cells in an 8P configuration was too few (2.5A discharge per cell)
Would go about 20km with a few mild hills (I'm 85kg) and battery would get hot, voltage would sag badly and BMS would cut out if pushed too hard.
2) 2nd attempt much better - 14S10P using Samsung INR18650-20R (and 25R) from recycled Ego 56V packs - each cells happy at 20A discharge so no more voltage sag.  Capacity is 20.58Ahrs or 1.07 kWhrs - easily gets me 26km to work including 3 very steep hills (Strava says 520m elevation gain).
Volts drop from ~58.8 to ~50.9V - so roughly down to 3.64V per cell so somewhat under 50% capacity (very roughly).
26km trip takes around 42min averaging 38km/hr - takes 5hrs on a 2A lead acid charger to get the volts back up.
A lot of fun to ride.  Done ~ 1,000km on it so far.
Recommendations:
a) use high current cells to avoid voltage sag you get with laptop cells
b) bus bars between cells in series to be min 20A capable (~ 4.6mm2 DC cable)
c) replace plug in connectors from controller to hub motor with soldered joints (a couple had melted when I looked)
d) upgrade thin wires from controller to hub motor with at least 4.6mm2 cable ~ 20A capable
e) make sure your bike has disk brakes ;D
BoomBoomShroom and Bdaearth like this post
If you haven't sourced your motor yet put some thought into a mid drive so you can still have 10 gears on the rear wheel.
http://dillengerelectricbikes.com.au/ele...afang.html
This is the kit I put on my bike but this was well before I found anything about doing a complete build yourself. I have the 11.6ah battery not a 13.2 as said previously, it was the only option when I got it, but you are building your own so you don't need to worry about that.
Hello Emerca, first of all sorry for my english, im spanish. I wat to make a battery for my 48v 1000w ebike kit. My ideas was: 13s10p battery with old laptop cells (all 2000mA). The controler can maximun off 26A. So 26/10= 2,6A per cell? Apart of that i wwant to put 5A fuses each cell? That was safety?, to discharge each cell to 2,6A? Thank you for readingSmile
(11-04-2018, 01:50 PM)IkerTronic Wrote: Hello Emerca, first of all sorry for my english, im spanish. I wat to make a battery for my 48v 1000w ebike kit. My ideas was: 13s10p battery with old laptop cells (all 2000mA). The controler can maximun off 26A. So 26/10= 2,6A per cell? Apart of that i wwant  to put 5A fuses each cell? That was safety?, to discharge each cell to 2,6A? Thank you for readingSmile
Hi IkerTronic - ha your english is fine mate - far better than my spanish!
Sorry to say I can't recommend laptop cells for an ebike - unless you go 13S20P (or go a lower wattage motor).
IMHO laptop cells are usually rated for max discharge at ~500mA - I have tested a few thousand at 1,000mA (on Opus testers) and they don't get too hot - that's why I say 20P min for laptop cells.  If it's your 1st pack and want to have some fun and don't mind damaging cells - your 13S10p will work for a few hundred km.
Another suggestion is to go 16S10P - the BMS is still cheap and the increased volts will lessen the amps.
The main problem is that an ebike battery using recycled cells must have a BMS and at say 20A on laptop cells they will heat up quite a bit, voltage will sag (amps increase) and will cause a low voltage disconnect - just when you don't want one.
Maybe do what I did and build a laptop pack, have some fun and see what happens while you get some high current cells from power drill packs??
And yes I fuse both +ve and -ve with .26mm copper wire to protect against shorts etc.
Good Luck!
(11-04-2018, 03:52 AM)emerca Wrote: Hey mate,
Recommendations:
I did some more research and was going to attempt a 13s10p setup. But from the info you guys seem to be giving me it seems like i need to avoid the voltage sag, so I'll attempt a 14s10p. I just need more cells. I sadly did a count recently and only have about 90 cells. Could have sworn i had close to 120 lol.
I plan to have a bus bar and fuses on my pack. What kid of bms do i need? Is it a 14s 52v 20A?
28 User(s) read this thread:
hbpowerwall (11-03-2018, 09:10 PM), brwainer (11-08-2018, 05:07 AM), rtgunner (11-04-2018, 04:23 PM), Bubba (11-04-2018, 01:08 PM), chuckp (11-04-2018, 05:27 PM), Beholder (11-04-2018, 10:51 AM), Ronald Hyde (11-12-2018, 11:07 PM), collinkoolen999 (11-14-2018, 09:07 AM), stevelectric (11-06-2018, 10:24 PM), IkerTronic (12-14-2018, 05:13 PM), Bdaearth (11-09-2018, 10:52 AM), Bedo (11-11-2018, 05:33 AM), newone972 (11-26-2018, 09:30 AM), BoomBoomShroom (11-19-2018, 03:32 PM), slimf (11-13-2018, 02:49 AM), daromer (11-04-2018, 02:40 PM), Sean (11-04-2018, 07:57 AM), mike (11-04-2018, 06:27 PM), Korishan (11-04-2018, 02:01 PM), PAF (10-31-2018, 02:56 PM), jdeadman (11-05-2018, 01:50 PM), wim (11-05-2018, 07:47 AM), watts-on (11-05-2018, 02:42 PM), jesusangel (11-03-2018, 09:31 PM), Stefaan De Ridder (11-05-2018, 03:17 PM), Geek (11-06-2018, 01:14 AM), emerca (11-06-2018, 09:45 AM), hnetto (11-29-2018, 02:02 PM)
