Evolve Skateboards Range Extender + Battery upgrade
#21
(09-25-2017, 05:40 PM)Scepterr Wrote:
(09-25-2017, 01:17 PM)The-J-Man Wrote:
(09-25-2017, 12:35 PM)Scepterr Wrote:
(09-25-2017, 12:31 PM)The-J-Man Wrote:
(09-25-2017, 11:17 AM)Scepterr Wrote: What motor controller are you using?
Standard one thats in the board. BMS is a original part too. Essentially its all identical, just a bit thicker, heavier and 74% more capacity.
Oh ok, I'm pretty sure a long battery wire would cause an issue on that too with attenuation and voltage ripple.  If you're not already on it, check out
https://www.electric-skateboard.builders/
Oh ok thanks. Ill have a look.
Whats better, a long positive wire or negative wire?
They should be equal, I would make neg longer if I had to
Ah ok, too late :Big Grin I did use some very high quality copper cable for the long positive wire. Building it the way I did made it the "easiest" and allowed for a protected middle channel for all the cables to lower the risk of a cable being rubbed open thats why I went with this design. It also allowed for an easy current spread over multiple nickel strips without needed too much of it.
I kinda did some overkill though with serial connections, I quadrupled the nickel which really isnt necessary from what Ive been looking at now. Double wouldve just been enough and triple plenty. Oh well Big Grin
43 User(s) read this thread:
jrxtrc (01-15-2018, 06:58 PM), zag2me (09-18-2017, 09:30 AM), Tostaki (10-31-2017, 03:34 PM), Jerty (12-29-2017, 02:50 AM), Gigatech (01-05-2018, 05:09 PM), IAMJAMESMANNION (11-10-2017, 01:40 PM), Bryn (10-18-2017, 10:23 PM), accoelho (10-02-2017, 07:03 PM), Timpass (10-18-2017, 12:00 PM), tocan (09-22-2017, 07:13 AM), Grumplestiltskin (09-22-2017, 07:22 PM), tomganleylee (10-30-2017, 09:06 AM), rebelrider.mike (09-19-2017, 03:31 AM), 1958 greyhound (09-19-2017, 10:23 PM), Jeremy Choy (09-17-2017, 11:07 PM), Robert Baumer (09-10-2017, 09:02 AM), The-J-Man (11-12-2017, 04:40 PM), frnandu (09-26-2017, 01:14 PM), wim (09-26-2017, 06:13 PM), jdeadman (09-26-2017, 03:13 AM), Scepterr (09-25-2017, 08:52 PM), Wattsup (09-29-2017, 09:44 PM), A + A (09-25-2017, 10:06 PM), Korishan (01-11-2018, 08:12 PM), ruby2 (09-20-2017, 01:23 AM), owitte (09-18-2017, 01:59 PM), mike (09-18-2017, 11:10 AM), daromer (09-25-2017, 12:09 PM), watts-on (09-25-2017, 11:02 PM), Dan Lim (09-17-2017, 08:32 PM), umop-episdn (09-15-2017, 01:39 AM), DarkRaven (09-25-2017, 09:44 AM), SimonW (09-26-2017, 03:22 AM), floydR (01-01-2018, 08:09 PM), jose215 (09-12-2017, 05:20 PM), Geek (09-21-2017, 03:44 AM), ivnz (09-25-2017, 07:48 AM), netmonk (09-08-2017, 12:27 PM), Dennis Van Hoek (09-08-2017, 09:15 AM), BlueSwordM (09-27-2017, 04:35 PM), Stefaan De Ridder (09-19-2017, 01:51 PM), Hanssing (09-18-2017, 08:16 PM), hbpowerwall (10-09-2017, 04:07 AM)
