Flyingwills
- Apr 12, 2019
- 5
Hi All,
Just needed some advice on wiring of fans to cool the new Eddi i installed a week or two back.
Using a 4W, 12V solar Panel -jaycar.com.au/4-watt-12-volt-solar-panels-amorphous/p/ZM9026
Noctua NF B9 REDUX 92mm - noctua.at/en/nf-b9-redux-1600-pwm
Noctua NF R8 REDUX 80mm - noctua.at/en/nf-r8-redux-1800-pwm
My question is what is the best way to wire these fans to the solar panel?
I currently have them both tapping into the solar panel at the same spot (In parallel). If i power them on at the same time both fans spin. However if i let the sun slowly power them up e.g. from sunrise, Only the 80mm fan spins untill i cover the solar panel entirely, let the fans spin down and then power them up.
Should i wire them properly in parallel?or series?
If parallel which fan in the parallel chain first? (does it matter?)
