garolittle
- Oct 27, 2017
- 100
I am getting different numbers when I run the following top speed calculation. Can you help? Assume the following.
Go Kart weight with batteries, motor drive system and driver: 400 pounds total weight.
Rear Wheels: 6 inch diameter (Rear Tires are Maxxis Pink with a 12 diameter)
Motor: AC-9 48V
Controller: 48V 600A Curtis 1236SE-5621
Running 600 amps (max) on level payment in 70 degrees Fahrenheit, what do you think my top speed would be with a sprocket ratio of 4-to-1. Thanks.
VenomKarts, LLC
VenomKarts.com
Augusta, GA
Motor: AC-9 48V
VenomKarts, LLC
VenomKarts.com
Augusta, GA
